AHC Inop after fluid change 2007 lx C1751 and C1762
Always happy to try something new. So with each test on lit up for about 1 second. With main relay, motor relay, front leveling solenoid, rear leveling solenoid I could actually hear something happening when it was activated. With accumulator solenoid, front gate solenoid, and rear gate solenoid I heard nothing... not sure what this means...
Take a picture of the data list as it stands now.
After the aformentioned tests I ran two attempts from l to n, neither managed to get to n. Here is the data after each failed attempt.
Ok, will do, any idea why I'm getting almost nothing
After the last bleed and attempted l to n the front was 4.6, rear 0.0, height accumulator 6.5. After this
Fluid comes from the globes no problem. I got ts data something like 4.5 front, 0.0 rear, 6.5 height accumulator after I tried to bleed the height accumulator last night... Usually I get a value for the rear too... I'll get some more ts numbers later when I can bleed more
I just tried two runs of l to n. The first time I got front 3.0, rear 5.5, accumulator 6.2 the second time I got front 4.0, rear 5.4, accumulator 0.0
If your pump is not working each time, guaranteed, then you'll want to address this first. Every time you crack a bleed valve and you run the motor, do you get fluid out? If so your pump is probably ok.
can u hear the pump running
Since you answered intermittent.pump operating.. I would disconnect the battery. Remove the electrical connector from the height accumulator. Inspect for wetness chaffing etc. Clean and reinstall. Remove and inspect each electrical connection at the pump and pressure sensor. While the power is still disconnected at the battery open the accumulator bleeder then when fluid stops completely carefully slowly remove the bleeder screw completely and clean and inspect it for clogging. Reinstall bleeder screw.
Also take lots of pictures of the pump height accumulator, each sensor, globes etc.
Report back before battery reconnecting.
Reporting back. Everything looked good. Wires good. Cleaned out all connectors with cleaner and compressed air. Should come to no suprise given what I have said before but I did not get a drop of fluid from the accumulator when I removed the bleeder. A little messy with AHC fluid and PB blaster in the vicinity. I hit each bleeder with PB blaster about a half dozen times before I started this adventure, I tried to clean up things before shooting the pics.
Correct, not a drop from the height accumulator and the bleeder was not clogged.
See last post. If you hear pump running when it stops shut off the truck and report back -prepare to reconnect to techstream. If no pump noise shut off the truck and report back. Prepare to check continuity at height accumulator.
Ok, pump is running.
It seems the pump sounds fine although fluid level is not changing. Let's look at the data. Ok looks like you are on bumpstops front and rear try the up button to neutral report back with another datalist photo.
First photo is as instructed. Second photo is after codes were cleared and second attempt from l to n.
