As the title says, I have deleted my AHC. Replaced with Ironman suspension. Now I have a vibration under load around 60-75 mph. Vibration is not in the steering wheel. Felt on the pedal. The harder I press the pedal the harder the vibration is felt. Tires have been rotated and balanced a few times to ensure they are not the culprit. Aligned a couple times as well.
Doing a lot of research on here and I believe it may be u joint, drive shaft, pinion angle related.
I’d like to test my theory prior to buying parts to hoping it will be the fix. My thought is to diagnose the issue is to remove the ironman rear coil springs and temporarily replace with the stock LX470 rear spring. (Anyone have some LC100 springs laying around and live in SC? ) If the issue is related to u joint, drive shaft, pinion angle my theory is that the vibration would go away.
Does my logic sound correct?
If this does fix the issue, will I ruin my rear shocks if I ride with the LX coil springs for a couple weeks? While I wait for parts?
thank you advance,
Jono
thank you advance,
Jono
