IndroCruise
Wow, that's so much info. Thanks again for taking this effort to help me out.
I've attached the techstream results. They were on a flat as I could find surface so clearly they are miles out.
1. Error codes remain unchanged.
2. Note that I have previously flushed ahc with new fluid
3.
At that point, the ECU initiates ‘fail safe function’ defined for C1751 -- meaning that
That seems to describe the symptoms on your vehicle?
- height control is prohibited, and,
- the AHC Pump stops and will not raise the vehicle, and,
- the vehicle adopts the height of the lowest wheel according to the signals sent by the Height Control Sensors to the ECU -- to do this the ECU opens the Front and Rear Levelling Valves in the Control Valve Assembly, allowing AHC Fluid to escape back to the AHC Tank, and so the vehicle settles.
The scenario you described DOES sound like what's happening.
I'm juggling 2 little kids and having to have a go at this bit by bit so excuse me if I can't get all the info for you immediately.
Gotta run but I'll have another read later
Cheers
Thank you for the Techstream screenshot. Other than the Height Control Sensor readings and the non-operation of the AHC system, there is nothing too alarming here. Voltages are a bit low -- need to watch these, Steering Angle is OK, Fluid Temperature is OK, Door Switch is OFF - OK, Brake Light Switch is OFF - OK, Main Relay Expectation is ON - OK, Ts and Tc are OFF - will think about these overnight, other switches and settings look OK.
When you can ....
- please confirm which are the two DTC's showing on Techstream,
- please advise whether the vehicle is resting on any of the bump stops when at your level place, and also,
- please measure and advise the hub-to-fender heights at all four wheels at the same place,
Measurements are a bit unreliable at anything other than N height because there can be some variations in the way the vehicle moves and some effects if the Front end alignment is out and/or if there is damage at the Rear end -- but at the moment, with AHC not working, there is no choice but to measure the vehicle in its current condition at the most level location you can find.
The idea here is to understand of how much of the Sensor difference might be due to a physical 'lean'? Is the vehicle actually low by a lot by tape-measure at the Front Right??? This also would usually mean that the diagonally opposite Rear Left is high (but depends a bit on any history of wear and tear and/or damage to chassis or body or mechanical suspension components, tyre type, pressures and wear being similar) -- but please tape-measure at all four wheels anyway.
If the Sensor readings are not accounted for by a physical 'lean' of the vehicle, then one or all of the Sensors (or circuits) are suspect -- mal-adjusted or faulty -- assuming that the Front end geometry and Rear end geometry is in reasonable shape, meaning no components, nor chassis, nor body are measurably damaged.
At N height, unless the vehicle has been 'lifted', for example using Sensor adjustments, and if it is basically in 'stock' condition, then around 19.75 inches (500 millimetres) hub-to-fender both sides at the Front would be good (if 19.50 inches also is OK) and 20.50 inches (520 millimetres) hub-to-fender both sides at the Rear also would be good.
If stuck at LO (not on bump stops) then would expect around 50 millimetres less at the Front, around 40 millimetres less at the Rear -- regard these numbers as guides, not measuring to the millimetre here:
If there is a 'lean', it is worth trying to correct this with the torsion bar adjusters, (engine OFF, do not want AHC system to suddenly 'wake up'), needs a good squirt of some kind of thread penetrating fluid on the adjuster threads the day before, then needs a 30 millimetre socket, a strong arm and possibly an extension bar or pipe of some kind, then see yet another attachment below labelled "AHC cross level per FSM".
In this step you are just trying to equalise Front Left and Front Right physical hub-to-fender tape measurements -- and if a tape-measure is available just use string or a marked stick -- don't worry about actual 'ride height' measurement numbers too much until AHC is working again -- because it is the AHC system and the Height Control Sensor adjusters which will be used to set 'ride height' eventually, not the torsion bar adjusters on an AHC-equipped vehicle.
So after Front 'cross-levelling', measure and record hub-to-fender at all four wheels again. Read and record Front Height Control Sensor reading and Rear Height Control Sensor again. (Note that height control is only Front and Rear on LC100/LX470 -- height at each wheel is not individually controlled by the AHC system on LC100/LX470).
Re-start engine. Re-start AHC system by pushing down ON/OFF switch for ~10 seconds, all doors and rear hatch closed, vehicle in PARK, foot OFF brake.
If you get a lucky break, this might be enough -- but I really think that there will be more to do.
Anyway, enough for today. Please consider -- and when you can, please provide an update with data as requested above -- and a path forward then can be discussed ......
By the way, if you can recall, please also advise what the AHC pressures may have been when the AHC system was last operational. Also suggest look for signs of AHC Fluid weeping at the 'shock absorbers' -- this may indicate a history of excessive AHC pressures.
