I recently purchased a 2007 LX470 w/90k miles. The truck is totally stock and in very good condition with one owner since new and a full service history from one Lexus dealer. No accidents, etc.
The AHC fluid was changed for the first time at ~70k miles but there is no indication in any of the records that anything in the system has ever given any trouble or required replacement.
I find the ride to be a little bit firmer than I expected but I have nothing to compare it to other than even stiffer riding lifted 80 and 100 Series rigs.
Over the past week I have done the Hi to Lo fluid level test three times and each time I get the same result - the fluid level in the reservoir changes approx 8 or 9 graduations, which I understand is on the low side of the acceptable range.
Today I bled the AHC fluid just to make sure it was perfectly clear/clean and free of air bubbles or contamination. The front bled fine with the fluid coming out smoothly, although with a dark grey hue. The rear fluid was just as dark but at least 50% of it looked slightly foamy with tiny air bubbles that almost looked foamy when I poured it into a large drain pan.
Is the foamy rear fluid a sign that the accumulators are ruptured or leaking or is it normal?
Other than subjective ride-quality test or the drop-a-wheel-off-a-curb-test are there any official Toyota/Lexus tests to verify the condition of the accumulators?
I would be
if I spent $1000 for new rear accumulators and the ride didn't improve!
Thoughts?
I would be
Thoughts?
