AHC bleeding...found foam/bubbles. Bad sign?
...Does this mean I need to raise the the FL sensor ('borrowed' photo attached) by sliding it up the slot or shortening the threaded rod until the Techstream reads about the same value as the RF?
Or maybe I need to lower the FL sensor position to acheive the correct number :confused:
Suggests moving one way and see what happens. Might end up adjusting both sensors (opposite ways) in order to get the desired height without the readings being to far apart.
How do I go about getting the techstream set-up? What is required, which parts, from where; and how much is the total cost?
Fixed! Needed to turn the FL sensor rod counter clockwise approx 2 turns.
Can't tell any difference in the ride height after the adjustment but it makes me sleep better at night :)
Was the foamy fluid just air getting in from the bleeding process? Mine did the same thing when I was bleeding a little fluid out to see if I need a flush.
