Advice Needed 94 Locked Cruiser
I discovered this site a couple of years ago and am continuously impressed with the knowledge and experience shared by so many. I need some advice and hope some of you are willing to take the time to weigh in on my issue.
I bought my first Land Cruiser in 2000. It is a 1994 white Cruiser with lockers and grey interior. I bought it from a relative, who was the original owner. I loved and drove it until until it had 270,000 miles. I had not found this site so I usually paid for service and did not maintain it like a good Mud member would. But it stayed reliable and is cosmetically very good.
My problems started with an oil leak at the rear main seal. I just added a quart of oil between every oil change. Then the power steering started leaking, so I added fluid every couple of weeks. The driver's seat then split in the regular spot. None of this was too bad, but I then developed an engine or power "studder," which actually lead me to this site. Based on my reading, I decided I must have a melted wiring harness. I also realized that there was a lot of work my Cruiser needed, including axel and locker service. With 280,000 miles, I also assume it may be time for an engine rebuild.
I decided I could buy a replacement cheaper than all the work needed, so in 2014 I bought a black LX450 with 120,000 miles (no lockers). The 94 sits in the drive now and I DD the LX. I like the LX, but miss my old white Cruiser. My wife is getting tired of the Cruiser in the drive.
Here is the advice part: I am trying to decide if I should fix up the 94 and sell the LX. I assume it will take at least $10,000 to do everything. Is that number low? Will it be worth that amount when I am done? While that may seem to answer the question, I love this truck and drove it every day for 13 years. I also prefer the white paint and grey interior over the black/tan LX.
The other options are (2) sell it as is; or (3) part it out. I doubt I could get much for it as is. I am not sure I could stand to part it.
Sorry for the ramble. Any advice/suggestions are welcomed.
The oil leak may be the pan arch vs rear main. If you're correct about needing the engine rebuilt, I wouldn't think 10K is "low" considering the while you're in there stuff. Not sure about your LX mileage and condition, but selling it to fund the 94 rebuild would be in the cards providing you have something for transportation while the 94 is being worked on.
Don't have a mechanic do the axle, it really isn't that hard. Since 1994 is THE ABSOLUTE UNDISPUTED BEST YEAR EVER...and it has lockers...go for it! ;)
"Rear Main Seal" leaks are probably the most common misdiagnosis on these trucks. @ewillis is on the right track...
A quart between oil changes doesn't seem that bad. I certainly wouldn't spend $6-8k just because of this.
Rebuild the knuckles yourself. $300 and a Saturday. It's messing as hell but pretty fun and you will be happy when you've saved a thousand bucks.
No, I would doubt that you 94 would be worth an extra $10k just because you put $10k in to it. It would be worth more than it is today but I doubt you would get all $10k back. And why would you want to do all of that work only to sell it. If you are going to do all of that then plan on keeping it.
Sell the LX. Keep the 94.
You have all the normal problems with an aging 94 other than the shudder. Please enplane the problem. Could be a stuck open EGR valve or other problem.
Rear main seal is 99.9% the rear main seal retainer to upper oil pan seal leak. I didn't remove the retainer when I replaced mine and had to drop the trans again to fix it the proper way. I assume you could remove the upper pan and try to reseal the upper pan but I have no knowledge if that works or not. Do a search or ask the forum.
Power steering leak, is it from the rear of the steering gear box? If so, if you dont want to spend $500 just put a good power steering leak additive. Mine has been seeping now for 100,000 +++ mi or more. I now only have to top off the fluid one or twice a year. Its still makes a mess but doesn't drip on ground. Lucas Power Steering Stop Leak has done me good.
Engine rebuild, you should do a lot of engine diagnostics, like compression test, leak down test etc. before you spend $$$$ on engine rebuilding unless you just want to have a complete ground up rebuilt 94 FZJ80.
If you have the $$,$$$ and the body and frame are in good shape, I see no reason not to invest the same amount or more as it would to buy a use 80. You will never get out of it what you put in it, money wise that is. If you plan on driving it till it no longer is road worthy, then spend the cash now and enjoy for years to come.
Second the RMS misdiagnosis. 290k here and mine doesn't leak a drop. Replaced valve cover gasket, front main, oil pump gasket, and both pan seals.. ZERO oil leaks.
Thank you for the advice. You are right that I would not sell the 94 after fixing it up-- I would like to drive it another 100,000.
The LX runs great. It is a 97 with 130,000 miles, but it was not cosmetically taken care of like my 94. I pulled the entire interior out when I bought it and washed/cleaned it. I installed sound deadening material and put it all back in. LX has the fake wood and seats look better. The 94's paint is actually better.
I will try the power steering stop leak. Mechanic told me it was the steering box an a new one was big $$. Since then I have discovered this site and learned a lot more about my truck. I have read the threads on rebuilding the box and know I can buy a rebuilt one. Of course, if the stop leak works, that will be the end of that.
The studder happens when you go from a stopped position and accelerate up to speed. It also happens when going up a hill. If I am going 65 on a flat road-- no problem. It also seems worse on wet/humid days. I first thought it was the tranny. I replaced all of the transmission fluid, no change. From all my reading on here, I think it may be the wire harness with a melted spot. I will read more about the EGR value.
I think I will start slowing fixing the engine/drive issues while DD my LX. Once the 94 is safely drivable, I can sell the LX and fund additional work, like new leather on the front seats, OME lift, new tires, . . .
Thanks
I added a cap full of brake fluid to my power steering reservoir. It does the same thing as power steering stop leak. It swells the seals. Did that 5-6 years ago. Doesn't leak at all.
I read about it on here.
Also have heard of people adding Fabric Softener. Never tried this but apparently it does the same thing. And if it doesn't work your fluid at least smells good. :P
Look at the transmission cable off the throttle. Is it hooked up? Check to make sure its adjusted too.
Remove the big black hose from the air cleaner to the throttle. Look carefully for cracks in the flex part. Check all the vacuum hoses, are they hooked up or cracked, broken? All the vacuum ports on the intake will have a vacuum hose for it.
^^^^ Yep. Sounds like a vacuum leak.
I would fix up the 94 if the cosmetics are that much better. Axle overhaul, complete with birfs should be around $1K with tie rod ends, brakes, rotors bearings and seals. That's assuming you aren't an OEM diehard. Use Japanese TREs, oem seals, timken or koyo bearings (cruiseroutfitters will get you setup) and Nitro birfs. Do OEM suspension bushings and a power steering pump rebuild for another 300-400 and your front end is all sorted out. Some seal work on the engine for another few hundred dollars. Of course you need several weekends to complete all that. If you enjoy it, go for it!
This! I have had a 91 and a 97 and I purposely looked for a 93-94 with lockers. Yes they are OBD1 but simpler in no airbags, etc.
First question- how is the rust. If it is rust free, I would fix it up and drive it. Newer cars are all the same and very "plasticky". Yes most of us have one of these, but we have our cruiser too. It's a classic with classic and enviable lines and more capable than just about anything else on the road.
You mention dollars, but it's hard to put a dollar figure on something that is sentimental and makes you smile. Most of us on here realize what we're doing is not the smartest decision with our funds, but it makes us happy. What's that worth?
If it does have rust, I would send it to the pasture. Mechanics are $ and easy, body work is $$ and specialized. If you do decide to sell it as a whole for parts, email me, I am always looking for parts and trucks.
A lot of great advice. Thank you all.
If I can fix the studder, I can start driving it again. I will start with replacing all hoses and vacuum lines, full tune up, throttle body cleaning, and transmission cable adjustment. Perhaps that will correct the studder. That all needs to be done regardless. It has never has a head gasket issue or replacement. Part of me wonders if I am at the point of it being easier to pull the engine. I guess if those repairs resolve the issues, no reason to pull it at this time.
Once the studder is resolved, I will tackle the steering box and front axel. I will then upgrade the suspension and tires.
It has always been an Arkansas Cruiser and has no rust. The only body work it needs is the passenger door on the driver's side. A teenager decided to "close it" with his shoulder and put a dent in it. The front bumper also needs repainting, but I always planned on replacing it a Slee bumper and winch when I fix it up.
I will get some pics to post. I guess I need them for my "before" if I do a build thread.
You all have convinced me to fix it up. I agree that the money is not the main issue.
I'd changed all of the vacuum lines if they need it anyway. But definitely check the "big black hose" going from the air box to the throttle body. This is a fairly common and known issue. If you see a crack wrap it in duct tape and drive it to see if that fixes the problem.
personally I wouldn't worry about the minor oil leak. But that's me.
Very well said...
"Most of us on here realize what we're doing is not the smartest decision with our funds, but it makes us happy. What's that worth?"
I really enjoy looking at photos of my kids in our 95 80 from years and years ago. So many adventures.
Was in a Toyota dealer last week and looked underneath a brand new 4Runner. Just can't compare that to a mid-90s 80. No comparison. That 4Runner cost more than a new 80 in the 90s - not addressing inflation of course - which says something...you just can't replace a solid 80 with a new vehicle...even a new $90k LC in my opinion.
Keep the 94. Enjoy your time with it.
If the "big black hose" is hard from age, you may as well replace it, might not be sealing very well. If it has never been replaced, you may as well do it as it will eventually need replacing.
Have you checked for an check engine codes? Does you check engine light (CEL) work even work at start up?
Here are some things you can do to rule some things out as a problem of your shutter:
Check the EGR for function or sticking. A IR thermometer helps with this test. Check the temp of the EGR pipe after driving. Let the engine cool down. Disable the EGR. Remove the small vacuum hoses and either plug them or do like link '94 Code 71, EGR Bypass and redneck technique.. . Drive and see if the pipe on EGR pipe is cool or hot. If its hot when its disabled they its stuck open. If its cool, check to see of the shutter is still there.
Unplug the 2 O2 sensors, they are in front of the cats. The CEL will come on when you do this but don't worry about that. Its fine to run with the O2 unplugged on the 94. Drive and check for the shutter.
After that, reset the ECU (computer) by removing the EFI fuse at the under hood fuse box for about a minute. Reinstall the fuse and drive, your RPM's will be low and run rough, that is fine and it will go away after a couple drive cycles. Check on your shutter.
