Adjustable Panhard source
Arizona
I am looking for an adjustable panhard rod for my 93 and was wondering what sources are available. What is the difference with a panhard with factory bushings vs the bushings Slee uses? They want extra for the factory bushings. I did some searching and did not see any recent discussions on this topic.
Slee bushings are fine for a panhard application and you'd get no advantage from rubber IMHO in the panhard because it does not take much twist.
I like the MAF 4+ the best (uniball joint on one end, rubber on the other).
times 2 on the MAF
Not that I don't like my Slee ones I just like the idea of the MAF's
just get some weld in joints and be done with it. And if you think that there is some binding in that rod with the rubber bushings just loosen the jamb nut on that joint while your off road. I personally have no trouble at all stuffing my tires.
Personally the rear flexes plenty good with just the joints that come with the factory. Making the rear flex easier is the wrong approach on our trucks in my opinion.
If I had a welder that would be a no brainer but unfortunately I do not have one at this time. My lift has shifted the front axle and I want to get this corrected. Thanks for the info, I will look at MAF!
I am looking for the front panhard rod, I did not see one for the front at MAF.
i am looking into these to right now, ive found slee , man a fre, and cammel 4 x4, the cammel ones which are made by ironman are the cheapest at 175
The price for the Cammel are attractive. Does anyone have experience with Cammel 4x4 products?
i dont know much about them either, except that price looks good, they did a review in 4wd toyota owner on the 100 series lift, but i think these will be the ones i order this week or next week, ill let you know if i get them
The camel ones are actually iron man 4x4 ones. They are, I believe, an aussie company.
Tools R Us, you are running the stock one with your lift and 37's? Your front end is not shifted to one side and pull?
Both front and rear are stock.
Yes my axles are shifted at ride height, no pull, if you have a steering pull it has nothing to do with panhard length. Axles shifted at ride height is purely cosmetic. My concern is more about stuff, big tire clearance and ease of flex. With an angled panhard, it's a pick your poison thing: Longer panhards shift the axle at stuff (full compression) causing, uneven tire clearance, pushes the suspension sideways at stuff binding it, but "look good" when parked. Stock length panhards stuff properly, flex easier, but look a little silly when parked. All of the adjustable panhards rigs that we have adjusted to work the best on the trail, then measured, were very close to stock length. So I don't see the point, unless your concerned about how it looks at the mall. :hillbilly:
So when the DS tire gets stuffed it will not rub prematurely? You would "think" with the axle shifted to the DS that the DS tire would rub easier than the PS tire would. You are saying that is not the case? I am just trying to see it in my head.
So the pulling is something other than the shifted axle? Does your tires wear faster with the dog walking ride?
i got the 4+ drop bracket for the rear panhard. like it much better than adjustables cause it keeps the horizontal angle. if i did adjustable, i'd do the slee weld it yourself stuff. i used the wiy upper control rod adjusters and they worked like a charm
Does the drop bracket still have issues? When did you get yours? The threads I've read say everyone has had to modify them to get the correct alginment.
The panhard angle is relative to suspension height/position, so at stock height it's relatively horizontal, when lifted it's more angled and becomes "short" for that ride height. It's still the same physical length, so is the correct/same length when the suspension is fully compressed. The axle/tire spacing will be the same when both suspensions are fully compressed. If if the panhard on the lifted one is lengthened to be "correct" at ride height, it will push the axle sideways more when compressed, causing more bind and possibly more tire clearance/fit issues.
If by dog walking, your referring to dog tracking, I don't see how a panhard would cause it? Dog tracking is an axle that isn't at 90 degrees to the rig center line, in other words one side toed out and the other toed in, so the tires aren't parallel with the center line. Most often caused by bent control arms, frames, axle, etc. In this case the tires are parallel with the center line, just slightly offset. This isn't going to cause significant handling issues or increased tire wear. Lots of vehicles come from the factory with slightly differing tracks/offsets between front and rear axles without issue, including the '80, the front is slightly narrower than the rear. As nuclearlemon mentioned the correct panhard setup is parallel to the axle/ground, so moving a mount is the proper correction. The ideal setup is as high as possible, so raising the axle end would be best. Unfortunately, on the front the panhard needs to be parallel with the drag link, so moving the mount/changing the panhard angle isn't really feasible.
Good point and you are correct. Thanks for helping me get my head wrapped aropund it (and out of my ass).
