Adjustable front lower control arms?
I've seen a set here on mud, but it was like $600. Pretty slick, but not for that much coin.
slee's control arms will push your axle forward
I'm sorry I miss read your post, I thought you meant caster adjustment.
How much is your lift & tire size.
I thought of that, but would rather not weld brackets on so it could be returned to stock.
The MAF drop brackets are bolt on. I have the 2.5" set.
One thing to think about that has stopped me from moving forward is at full compression it will not be center in wheel well & may increase rubbing. What size tires do you have & how do you use your rig?
These are Super Pro adjustable bushings...
