Plastic bag with corner snipped off, like a cake decorating bag. Squeeze bag inject grease
You gotta take SOME stuff apart to get in there...what's the most simple access into the guts of this creation?
Genius!I think the OP already has the whole axle and birfield out at this stage.
One another note, RCV birfields like I have in my 80 series have a grease zerk on the end which allows you to grease grease them without pulling the axles out.
Genius!
There's a square plug on the inside top of the joint--is that access into the guts?
Fulltime 4wd on mine. The birfields were rebuilt in Oct 2021.That is a grease port yes. You can squirt a bit in there from time to time but a properly sealed/built front knuckle does not need it.
Keep in mind, unless you are running drive flanges and not hubs any part time Land Cruiser (40/55/60) front axle does not turn unless the hubs are engaged.
Usually that is a small number if actual miles over the life of a Land Cruiser.
