Activating the ABS
Malleus
contact@Restore4x4.com
Supporting Vendor
Charlotte, NC
After trying for several hours, unsuccessfully, to get the air out of the brake system, I can only believe that some pesky bubbles are hiding in the ABS system.
Does anyone know of a way to activate the system, safely, without damaging it, to purge the air from it, so that it can then be bled from the lines, without slip-sliding on a gravel road, which I cannot do (there aren't any close enough for that to be practical, or I'd have already done it).
The problem is not in the master cylinder or with a plugged bleeder screw. I just replaced the front calipers, and installed new bleed screws on all five points. The master was always wet during the process and the bleed screws discharged normally (that is to say they disgorged crap and fluid).
You have to actually drive it.
Find a safe area first. Two wheels on pavement, two wheels off pavement. Slam on the brakes.
Repeat on each side a few times.
Rebleed the system after that.
There is a Toyota SST but it's ungodly expensive. Hence, dirt road. Also I've found that slamming on the brakes will going over small speed bumps will also activate the ABS.
Thanks guys, I'll give that a try.
Have you looked at the LSPV? Air hides in there easily and its tricky to purge.
You can also take a look at the LSPV with the boot removed. The piston on mine was rusty and visibly wet with brake fluid, but hadn't leaked enough to be visible with the boot in place. Bleeding the LSPV would work temporarily but I ended up replacing it.
Good luck with the brake bleeding!
Thanks for the thoughts concerning the LSBPV. That's the fifth point I bled. It has a bleedscrew, just like the calipers and is bled the same way. The FSM says to bleed it last, so I did, although it makes more sense to me (theoretically) to bleed it third. I'm not too worried about its function because I recently replaced it with a new unit.
You are welcome to borrow and use Home Page - Phoenix Systems Brake Bleeding , I got one here in Charlotte. They worked great for flushing break fluids from difficult cars where ABS air bubbles get trapped on one direction and continued normal flush won't dislodge them. Also have a motive power bleeder Domestic Power Bleeder Kits if that works better. Let me know.
I bleed it third. Fronts and tears are controlled by different parts of the MC and ABS.
I had alot of trouble getting the Motive pressure bleeder to seal against the master cylinder reservoir. The "universal" adapter always wanted to leak and spray DOT3 everywhere!
I bought a Toyota specific adapter from the mother ship and it works wonders with the Motive bleeder!
CTA Tools 7041 Adaptor - Toyota / Lexus https://www.amazon.com/dp/B005B4N6RY/ref=cm_sw_r_cp_apa_r8UqzbY7DC3HZ
Assenmacher Specialty Toyota Brake Bleeder Adapter TOY18B https://www.amazon.com/dp/B01HZ2QZK4/ref=cm_sw_r_cp_apa_X7UqzbSK9XVAE
Thats right, it can be a mess. I found out using zipties worked fine, or using a couple of plastic adjustable clamps to hold it down. Motive bleeders are great, I do full flush and is pretty easy.
Got the Phoenix when racing VW's, apparently it was a well known fact to that racing crew that the ABS would trap bubbles (hard brake application), and they would be downstream of check valves, so the motive bleeder didnt remove them as it was pushing against the valves. But the Phoenix will push them out by going against the flow, open the check valves and push the bubbles out. Who would have known....
I tried SpeedBleeders but they leaked :(
Funny you should mention that. Three wheels worked well, but the driver's side rear wouldn't accept a Dorman speedbleeder; I had to use a Russell. I tried two Dorman's and they both leaked. I had to replace the OEM because it was plugged and I didn't have time to flush it.
It does piss me off that the LSBPV thread is smaller than the calipers.
UPDATE
In the past, I gratefully paid for a complete brake bleeding due to the hassle of performing it on the 80 series system. Sometimes I could do it once and be done, other times, no matter what I did, I couldn't get the air out. Thanks to @Izzyandsue I'm now a Motive fan. I've easily spent enough money to buy one of these systems in the past and I'm ordering one this week, so Izzy can have his back.
Just a quick review: in less time than I spent bleeding the brake system, I not only successfully bled all the air out of the system, but completely flushed the system at the same time. I'm a fan.
Seeing the tools you posted made me think about my Mityvac oil suction device.
Would this work too. 8L capacity lots of negative pressure.
