"Acid For Blood"
Iceaxe
I am my rig's nemesis.
Reno
So, THIS happened coming up and down and up and down through the Sierras today. Engine temp between 205-220. Ran reasonably well despite the high temps.
1. I'm guessing this is the EGR, right?
2. Why did it explode at the top and bottom?
I have an SC'd rig....
Sheesh, I don't know... But it sure detonated!!
Doesn't look like it's ever been replaced... Funny thing is the truck drove fine anyway on the way home.
I believe that is from a bad hose, the one leading up to the underside of the egr valve.
The pulsing of the exhaust is only meant to influence the modulator. If the hose is a sloppy fit then hot exhaust gasses can stream out that leak and get hot enough to melt the modulator. I've seen this before and when installing a SC I use a new factory hose in that position.
Land tank, so, if I replace the modulator and get a new hose that ought to fix the issue?
I was thinking that could happen if the diaphragm was bad in the EGR valve , which would allow hot exhaust gas run back to the modulator. Normally the exhaust gases never pass thru the plastic parts.
Mine was melted when I got the truck. I got rid of all that crap shortly after.
Ok great, thanks land tank. I have to say, that's the coolest part failure I've ever seen.
What's cool about this failure too is the fact I can drive all over the place. I'm thinking about not doing anything about it, as it seems I have a naturally occurring EGR-delete!
