Accessory Wiring Advice Needed...
EPIC Cruisers
Supporting Vendor
ATL
Website
www.epiccruisers.com
Hey everyone,
I am looking to wire up a few accessories on my 80, however I'm having a hard time figuring out what gauge wire I should use for each circuit. Wiring has always been a nightmare for me so please help me out. I want to make sure I have the adequate sized wire for the job.
The first thing I'm trying to wire up is the USB socket below, and I want to wire it directly to the battery so it is always on...
- USB Charger Socket - Output: 5V/3.1A, 7V/2.4A, 9V/2A, 12V/1.5A (Amazon product ASIN B07LCBKZSG)
It list various voltages/amp outputs so I don't understand which amp rating to use to find the correct gauge wire on this chart (Know-How Notes: Automotive Wiring Guide - NAPA Know How Blog)
Could someone please tell me what gauge wire to use? And also how they figured it out?
Thanks in advance!
I use this and its pretty good circuitwizard.bluesea.com/#
I actually found this during my research, but honestly didn't know what to plug in. Like I said I'm horrible with wiring/electrical stuff.
Your feeding it 12v and it's a 36watt charger so take 36÷12=3. So you need wire rated for 3 amps.
Perfect! This is exactly what I was looking for, I needed someone to break it down like this so I could understand. Thank you!
Proper fusing is the most important part of the wiring.
Understood, from what I understand you're actually fusing the wire and not the device itself. Aka you don't want the wire to fail and heat up/cause a fire.
Correct?
Place the fuse as close as possible to the battery, the fuse will protect everything after the fuse, the distance between the battery connection and the fuse is not protected by the fuse.
Depending how far from the battery you are placing the USB device, you may want to use a little beefier wire than the minimum specified, ie back of the truck vs front center console.
Okay got it. I am going to use one of these Blue Sea System fuse blocks (Part #5045)...
Amazon product ASIN B01BV1MS1K
Do I need to put a fuse on the wire going from the battery to this fuse block? Or is that not necessary?
An update, and follow up question. I have installed the USB plug and it works great, thank you to everyone for the help. However the possible drain of it being wired directly to the battery when not in use has me worried. Therefore I want to install a discrete switch that will turn power off when not in use. I plan on installing the switch on the negative wire going to the USB plug.
I found the perfect sized switch but it is AC not DC. ( 6A 125VAC, 3A 250VAC, 3A 250VAC T100/55 )
Could I still use this switch? Or is it better to find a 12VDC switch? It seems like the majority of the smaller sized switches are VAC.
