AC Question
Why are wanting to convert to R134a IF you indeed have a system that is not leaking?
IMO...unless you take the time to do a conversion right, you are setting yourself up for a disappointment.
R12 can still be had (yes its more expensive..but available). Your system is already set up (optimized) for it.
If the system has been exposed to atmosphere for any appreciable amount of time (more than a day or two) then you will want to replace the dryer. I would also recommend replacing the mineral oil in the compressor and replace any O-Rings you can easily get to.
You want be dead certain you have no leaks before recharging with R12 (if you choose that route) because of the expense.
Hope it works out for you.
Flint.
Thanks Flint.
That is why. The expense. A shop in Portland quoted me $650 for a refill. Seems little rediculous to spend that much.
Thanks Flint.
In post #17, I provided a direct link to the Toyota TSB. You can download it and do the retrofit your self, it’s no big deal.
