AC Line Replacement Help Needed
Michigan/Costa Rica
The high pressure aluminum line that runs along the firewall on my '94 FZJ80 was corroded and leaking. It is routed in the most inaccessible route. I have a new replacement that I'm trying to install. I got the old one out but it came out in pieces. In addition to removing the heater valve and all the heater hoses that go through the firewall, it looks like I have to remove the master brake cylinder and the brake booster to get the new one in place. Am I missing something? Has anyone had any experience replacing this line that can give me some guidance? Any help would be graetly appreciated.
If you need help getting to the bolts that hold the booster, let me know. I know thats a tough spot to get to...
I had the same problem on a 1994 18 months ago. I took it to a Japanese specific shop and they quoted me 2 hours. They told me that they would remove the master cylinder and force the brake lines to flex a little. That line is a really tough job and since this particular cruiser had some rust I did not want to deal with, I sold it and passed the new line onto the new owner. Lost my12mm wrench behind the engine and I never did get it back! LOL I know this has been no real help so good luck and just keep chipping away at it.
It is done!
A nightmare from hell best describes this job. It took me a good 12 hours to replace this line. What made it so difficult is the line routing. It runs along the firewall, behind the engine and under the brake booster. One of the clamps that attaches the line to the firewall is very difficult to remove and reinstall due to the location and lack of clearance. I had to bend up an offset 12mm box wrench to be able to reach the clamp bolt behind the head. This would be relatively simple job if done while replacing a head gasket.
In summary, here is what I ended up doing:
Disconnected both heater hoses that go through the firewall
Removed the heater control valve
Unbolted the electrical harness from the firewall and pulled it forward
Removed the master brake cylinder
Removed the brake booster
Disconnect the accelerator cable and pulled it back through the firewall
Unbolted the a/c suction line from the firewall
Disconnected and removed the high pressure line. I used my home-made offset 12mm box wrench to access the one bolt that is behind the cylinder head.
Installed the new line. I used a new o-ring for the line at the left fender end. The o-ring at the firewall end was included with the new line. A hint: Carefully position the clamps on the new line that attaches it to the firewall, using the old line as a guide. The real hassle is installing the one clamp bolt behind the head.
Reinstalled all the stuff that I had removed/disconnected. I used a new o-ring for the suction line.
Bled the brakes
Topped off the coolant
Recharged the a/c.
Wow, that sounds like a royal PITA!
Is the A/C nice and cold now?
Oh man, I almost don't want to tell you this, but here it goes : you didn't need to do half of that. You can run that line up under the booster and all that crap, I think i did disconect a few hoses on the firewall. It took me about an hour but I finally had to very carefully bend the line to make it around a few things, then bent it back. Its been going strong for over two years now.
Great write up! Thanks
I thought about trying to bend the line to get it under the booster but was afraid that I would kink it. The MC/booster removal was time consuming but not that difficult. The biggest struggle was getting the bolt behind the head back in place.
Golgo13: Blows nice and cold. I did recharge it with EnviroSafe rather than R134. I've used EnvriSafe on multiple vehicles and it works great.
I thought pulling the line out was a b****.
Can't wait to put the line back in (NOT).
I'm with 1/2 cruiser on this one though....gonna make a few slight bends and feed it under the MC/BB.
Nice write up though!
