AC leak question
STerling VA
I need some help here. About 3 weeks ago i noted my AC not engaging after pressing the AC button. I pulled out R134a kit and verified i was out of gas. Having put filled the AC with gas i was getting cold air woohoo.
This am having pressed the AC button and noted the AC not engaging i am willing to bet there is no gas again.
My question is is there a specific joint (which may have a rubber that worn out), or place in the AC system i should look at to try and identify where the Gas leak is occuring, or is this something i should just take to TOYOTA and have them rectify.
Thanks in advance for the help.
94 - LC with nothing on its, bare minimum.
follow the lines. You probably will see oil where the leak is.
Howdy! Just look for any wet spots on the system. You can buy cans of 134a with a flurescent dye in it. It is so bright, that you can often see it without the required blacklight. Or you could take it to a regular A/C shop. Save a buck or two that way. John
lots of places for the leak .. I thought I will go first to check on the inside unit .. if there are no visual spots with oil around the circuit, tubing front condenser ..
Howdy! Yea, if you find the wetness around the compressor, you may be out of luck. There goes your entertainment fund. John
Check the metal line behind/near the right headlamp where it connects to the condenser. Use a flashlight and if you see oil and accumulated dust there you will be a lucky guy if that's where it's leaking.
DougM
I had that problem too. The issue was the condenser had eroded from the salt on the roads and it was leaking like a seive. We used the die to find the leaks and then replaced the condenser.
I was totally clueless about it all at the time and ended up paying nearly 1200 bucks for the service. I just love being ripped off :bang:
I took mine to a good shop for evale today and was just told compressor seal was leaking at a cost estimated at $1400 to repir and replace misc. parts, there has got to be a better way.
1400 bucks !!!!!! :eek: change the compresor outer seal aren't gona cost more than 200 bucks here ..
