AC is not cold
I have a 96' model 80 series which we bought in Spain and drove to Mauritania. It's hot here...HOT.
But, I'm a little surprised that our AC barely works. When we were in Spain is worked incredibly well (just a couple months ago) - it barely seems to cool down now. We rarely use but today I tried to test it out.
I believe the fluid is good. Is there something else I should consider? Is it possible that I need to blow out our air filter (which I don't believe is in such bad shape anyways).
Looking for common things to check - hoping we don't need to repair a part for this (hard to get parts here period). Or, is asking it work on a 40C/100F day too much?
Check the Receiver/Dryer under the hood right side at radiator, there should be a glass eye...you should see fluid moving through this with engine running and AC on.
Check this and then decide to either live with the heat, or recharge the system with freon. A good shop will do a leak test before a recharge.
Good A/C at ambient temps over 100 are very dependent on cooling system being well tuned. May need to flush radiator and/or replace silicone fluid in fan clutch. Lots of discussions of this on the 80s forum. John
One other thing to check is the AC fan belt. Loose fan belt could be the problem.
When we lived in Mali the ambient temp made our AC run horrible but now that we are back in the states its just fine might want to look at getting an auxillary fan that helped a little also like everyone else said general cleaning and maintenance.
