AC delete
Wyoming
Cant find much info on this topic. I'm swapping an engine I got from a wrecked 94 into my 93. I live in north west Wyoming where a/c is not needed. Is deleting the ac system as simple as just removing the compressor and lines or is it more complicated than that and not worth the trouble?
It can be as simple as not installing the belt. So, yes. You do not need to install the compressor or lines if you choose.
However, I would at the very least plug your condenser and evaporator lines as a "permanent" plug with an actual threaded cap so debris and moisture do not get into them in the event that you choose to reinstall the system in the future.
Even in cold climates AC is nice to have for defogging the interior windows. As for the delete there's a condensor, evaporator, lines, drier, etc... which wouldn't really make sense to remove since they aren't in the way.
Leave everything where it is, plug the lines properly and just remove the belt. Don't make a headache for the next guy who might own your truck when you're done with it.
