Thank
@bloc but it turned out I'll need to replace the compressor because the pulley has damaged it.
When I get some time I'll post the mistery of the missing washer.
The compressor turns by hand. It is a somewhat uneven resistance but that can be caused by the pumping it is doing being conected to the AC pipes not on a bench. I don't know.
Anyway need to order a new one and get a condenser to go along with it.
BTW do you know if the Toyota compressors come with oil? FSM says to add oil. All aftermarket compressors including Denso come with oil.
Talking about aftermarket, do you guys trust they put the right amount of oil or do you drain and refill per FSM? Can the oil actually be fully drained?
