AC compressor question
My AC compressor makes a very loud chirp when it is turned on. I got part numbers from Toyota for a compressor, clutch, and idler/tension pully. Do you think it all needs to be replaced or just one part? It cools just fine, just a loud chirp.
I would first check the belt and the pully. Next would be the clutch.
Easiest to take the scid plate off to make sure the pully is tight and watch/listen as someone turns it on.
The belt broke....So I need to replace it if I need to further trouble shoot it. If it only chirps when the compressor is on, could it be just the pulley? How do I diagnose compressor vs. clutch?
...and before the belt broke...my dad squirted some wd 40 in front of and behind the pulley attatched to the compressor and that made it shut up for a few days.
A loose belt will cause squealing.
Dust between the clutch plate and pulley can cause chirping or squealing.
Insufficient oil in the system can cause a squeak on compressor startup. (I don't think this is your problem.)
A failing idler bearing can cause a squeal, but is more likely a groaning type noise.
A loose belt will cause squealing. It may only last a second or two at startup.
i would take the pulley off while you had the AC belt off and see if it is going bad (i.e. "chirps" or has any kind of bind when you spin it). that could be your problem. if not, then look at the clutch more carefully. in my limited experience when the clutch goes bad it makes a progressively worsening noise and mine kinda wobbled on the nose. if it's doing anything of the sort, get it checked out or get the a/c vacuum'd down and take the compressor and clutch off yourself and inspect the clutch sooner than later. if the clutch has a bad bearing or is going bad, it can wear the nose of the compressor and then you'll be buying/replacing a new clutch AND compressor. ask me how i know...
