Hi All,
I have a 1999 VXR that I've had throughout the Middle East and am now in North America. Fairy recently the AC compressor was replaced, and the system was charged somewhat recently too. None the less, there must be a small leak and the system is empty again. I went to go charge it and got myself a set of manifold gauges and couple R134 cans. After running the vacuum gauge for about an hour on it, I go to charge the system. I hook the can on, screw in the pin on the top of the connector that goes on the can, and open the low pressure side with the car running, cool box, rear, and main AC all on max. The gauge jumps to about 55 psi but the compressor never cuts on. Wondering if its the compressor, the low pressure sensor not letting it cut on (and if so perhaps because I am filling wrong?). I am leaning towards the pressure not actually jumping up in the car. When I tried bleeding the yellow line I'd here a little preasure release, and then stop, but no real spray coming out. Also I should be observing more in the window I would assume?
Thoughts? Probably a pretty rookie question but reading through the other AC help threads and youtube videos I am stumped as to what I have wrong.
Thanks all!
Thanks all!
