Absolute Wits End Part Numbers List 98-02
Aurora, CO
I've done my best to pull all the part numbers from the 98-02 page. Please check all p/n before ordering. If anyone finds more part numbers to add, please post them and I will update.
Toyota magnetic differential plug kit- $11.45
  • (2) Magnetic Drain/Fill plugs 90341-18021
  • (2) Steel crush washers 12157-10010
Constant torque spring clamp for ¾" OD & 5/8” ID heater hose- $4.60
  • 90467-21010
OEM Magnetic Transfer or Trans Case Drain Plug Kit- $11.90
  • (2) Magnetic Drain/Fill plug 90341-18021
  • (2) Aluminum crush washers 90430-A0003
Oil Drain Bolt Gasket- $10.45
  • 90430-12031
Toyota FIPG 103- $18.00
  • 00295-00103
  • Suggested Applications: Valve covers, oil pans, intake manifold end seals, timing covers, water pumps, thermostat housings.
Fuel Injector Connector Housing-$10.60
  • 90980-11153
Heater T- $11.70
  • 87248-60460
Combination Meter Light- $5.60
  • 83120-60020
  • Combination Meter Bulb NO.1, 12V 1.4W, w/socket.
Driveshaft Hardware Kit-Front 10mm- $35.85
  • (4) bolts: 90105-10424
  • (8) washers: 90560-10H00
  • (8) lock nuts: 90178-10006
Automatic Transmission Drain Plug and Washer-$6.80
  • (1) 90341-10011 OEM drain plug
  • (1) 35178-30010 OEM washer
OEM Steel Wheel Chock- $26.70
  • 09184-00010
2UZ Fuel Filter- $47.70
  • 23300-50090, filter
  • 90923-07002, green clip
2UZ Heater Hose Kit-$203.75
  • (2) Heater T pipe (87248-60460)
  • (1) Heater hose (87245-6A180)
  • (1) Heater hose (87245-6A190)
  • (1) Heater hose (87245-6A800)
  • (1) Heater hose (87245-6A210)
  • (1) Heater hose (87245-6A220)
  • (1) Heater hose (99556-20155)
  • (4) Hose Clamps (96136-52101)
  • (8) Hose Clamps (90467-21010)
Brake Pads Front- $103.50
  • 04465-60230
OEM Oil Filter-Small- $5.10
  • 90915-YZZD3
OEM Rear Caliper Bolt Kit- $8.30
  • (2) OEM Toyota Caliper Bolts (90101-12167)
  • (2) OEM Toyota Washers (90201-12452)
2UZ Valve Cover Gasket Kit- PRE 08/2002- $96.40
  • (1) Cylinder head cover gasket, RH (11213-50031)
  • (1) Cylinder head cover gasket, LH (11214-50011)
  • (18) Cylinder head cover bolt w/seal (90080-10330)
  • (8) Spark plug tube seals (11193-50010)
2UZ PCV Kit- 1/1998-4/2005-$72.75
  • (1) Valve sub-assembly, ventilation (12204-50020)
  • (1) PCV grommet (90480-18001)
  • (1) Ventilation cap (12235-50010)
  • (1) Ventilation valve cover (12236-50010)
  • (1) Ventilation hose (12261-50050)
  • (2) Hose clip (90467-15021)
  • (1) Ventilation hose (12262-50030)
  • (2) Hose clip (90467-20010)
Lithium Soap Based Glycol Grease-$9.75
  • 08887-01206 Rubber-G 100G
Toyota FIPG 1281 Adhesive- $26.70
  • 00295-01281
  • RED adhesive for the transmission pan &tcase
2UZ Radiator Hose Set- $76.70
  • 16572-50150
  • 16571-50150
Power steering Return Hose 3/8”
  • Hose Size: 3/8"
    Outer Material: Polyester braid
    Hose Length: 36in.
    Hose Inside Diameter: 0.375 in.
    Minimum Recommended Temperature: -55 deg F
    Maximum Recommended Temperature: 300 deg F
2UZ-FE Power Steering Return Hose 5/8"
  • Hose Size: -12 AN (5/8" or 16mm)
    Hose Length: 24in.
    Hose Inside Diameter: 0.625 in./16mm
    Hose Outside Diameter: 1.080 in./24mm
Body Grease- Molykote 102- $67.10
  • 08887-02007
  • windshield motors and the diff e-lock motors
2UZ Serpentine Belt-$55.00.
  • 90916-02586
Speedometer Sensor O-Ring- $4.00
  • 96711-24030
2UZ Air Filter- $27.90
  • 17801-50040
2UZ Vacuum and Vapor Hose Kit- $212.40
  • (1) 17030-50070 Hose No.1 Idle-Up -fits 1998-2006 2UZ
  • (1) 17341-50110 Air hose -fits 1998-2003 2UZ
  • (1) 23829-50070 Fuel vapor feed hose -fits 1998-2003 2UZ
  • (1) 77249-60140 Fuel emission hose -fits 1998-2003 2UZ
  • (1) 17345-50080 Air Hose No. 5 -fits 1998-2003 2UZ
  • (1) 77747-60031 Charcoal canister tube -fits 1998-2003 2UZ
  • (1) 90999-92003 3.5mm vacuum hose
  • (7) 96132-51300 clamp
  • (1) 90080-46347 clamp
  • (2) 96135-51100 clamps
100 Series Cabin Air Filter- $20.00
  • 88568-60010 2 needed
OEM Wire Harness Tape- $38.45
  • 82997-12010
100 Series Front Axle Boot KIt, one side-$72.65
  • 04427-60120
Toyota OEM Brake Caliper Grease- $28.80
  • 08887-80609
2UZ OEM Oil Cooler Kit- Maintenance- $94.50
  • (6) 90467-20011 Hose clamps
  • (1) 16281-50030 Hose, water by-pass, no.4
  • (1) 16282-50040 Hose, water by-pass, no.5
  • (1) 15777-50030 Hose, oil cooler
  • (1) 90301-67004 O-ring (for oil cooler)
  • (1) 15695-50010 Valve assembly, oil cooler relief
  • (1) 15692-50020 "figure 8" engine oil adapter seal
3-Wiper Blade Kit- $73.75
  • (1) Front wiper blade assembly, LH (85222-50040) - fits to 2003 (unconfirmed if fits 04-07)
  • (1) Front wiper blade assembly, RH (85212-60171) - fits all 100s
  • (1) Rear wiper blade assembly (85242-60050)
2UZ Power Steering Pump Reservoir- $200.10
  • 44360-60210
Complete E-Brake Kit- FZJ80Series and 100 Series- $731.30
  • (2) 46341-35030 Parking brake equalizer
  • (1) 90949-01614 Brake clamp
  • (6) 91611-G0820 Bolt w/washer
  • (2) 90468-A0006 Brake clip
  • (2) 90468-03006 E-brake clip
  • (2) 90240-08059 Pin w/hole
  • (2) 90385-12012 Brake bushing
  • (3) 90170-A0001 Hex nut
  • (1) 90109-08206 Bolt
  • (1) 46469-60030 Cable guide lever
  • (1) 90119-08701 Bolt w/washer
  • (2) 90119-A0109 Bolt w/washer
  • (2) 90080-11199 Bolt w/washer
  • (12) 90179-12118 Nut
  • (2) 47447-30020 Shoe hold down spring pin
  • (2) 47447-50010 Shoe hold down spring pin
  • (2) 47639-30020 Bellcrank stopper bolt
  • (1) 47624-60022 Parking brake bellcrank, RH
  • (1) 47625-60022 Parking brake bellcrank, LH
  • (4) 90506-20033 Tension spring
  • (1) 47633-60010 Bellcrank boot, RH
  • (1) 47634-60010 Bellcrank boot, LH
  • (2) 90249-08075 Pin
  • (1) 47628-60010 Bellcrank bracket
  • (1) 47629-60010 Bellcrank bracket
  • (2) 90213-06013 Type C washer
  • (2) 47459-30010 Shoe guide plate bolt
  • (2) 47456-20030 Shoe guide plate
  • (0) 90507-A6001 Tension spring- DISCONTINUED
  • (2) 90016-DY008 Spring
  • (2) 90501-A0004 Compression spring
  • (2) 47613-60020 Parking brake strut
  • (2) 90506-12068 Tension spring
  • (1) 47405-60010 Shoe adjusting screw set
  • (1) 47406-60010 Shoe adjusting screw set
  • (2) 90506-12029 Tension spring
  • (4) 90501-16053 Compression spring
  • (4) 47449-30030 Shoe hold down cup
  • (4) 47449-40010 Shoe hold down cup
  • (2) 90249-07074 Pin
  • (2) 47616-60020 Parking brake wire
  • (2) 90213-04001 Type C washer
  • (2) 90564-09185 Shim
  • (2) 90213-07018 Type C washer
  • (1) 47611-60030 Parking brake lever, RH
  • (1) 47612-60030 Parking brake lever, LH
  • (1) 46540-60050 Parking brake shoe assembly
  • (1) 46580-60050 Parking brake shoe assembly
  • (2) 46550-60060 Parking brake shoe assembly
2UZ AC Piping Clamp- $52.45
  • 88718-60880
Spindle Needle Bearing and Bushing Set- $72.40
  • (1) 90364-33011
  • (1) 90381-35001
Hose Clamp, Fuel Vapor- $1.50
  • 90080-46347
Transfer Indicator Switch- $97.85
  • 84222-12010
2UZ Thermostat and Gasket set- $30.90
  • (1) Thermostat 90916-03100
  • (1) Gasket 16346-66020
Toyota Windshield Washer Fluid- 1QT - $9.75
  • 00475-00WWF
Gas Cap for 1998-1999
  • 03/1998 - 08/1999
  • 77310-48020, replaces: 73310-01012, 77310-01012, 77310-06020, 77310-01011
Gas Cap for 100 Series- 2000-2006- $28.90
  • 04/2000 - 05/2005 = 77300-53010
  • 77310-48020
Fuel Filter Tube Connector- Green Clip
  • 90923-07002
OEM High Beam Headlight
  • 90981-13046
OEM Low Beam Headlight
  • 90981-13047
100 Series Power Steering Rack Rebuild Kit- 98-02
  • 04445-60080
  • Fits: (01/1998 - 08/2002)
OEM Panel Trim Retainer- Maroon
  • 67771-12050
Thanks for posting all the numbers that was a lot of work and much appreciated!!!
