ABS light
Boulder, CO
This morning my ABS light came on, and I'm wondering how to troubleshoot it, will it throw a code much like the CEL light does. I just rebuilt my front axle this past weekend and in the process noticed a few small metal shards on the ends of my abs sensors which I simply cleaned off before reinstalling and thought nothing of it. Any good threads discussing this, searched for ABS but came up emptyhanded.
Yes I believe it does throw a code. But I am not sure about the process of pulling the code on a '96. Someone may need to correct me but I am pretty sure you will need to take it in because you have OBDII as the diagnostic system. Be thankful that it did throw a code because that should help locate the problem. I am having ABS issues right now and for the life of me cannot pinpoint the problem because no code has been triggered.
For OBDII you'll need a scanner. Most auto parts stores will pull the code for you for free.
Well, it worked on my '97, which is OBDII. Most scanners can't pull ABS codes, only ECU codes. You can't jumper the '95+ for ECU codes, but you can the 93/94.
My friend has a '95 80 that when he was servicing the front axle, he hit the ABS sensor when removing the PF birfield. It bound up at first, but then he realized that he should just remove the sensor. Ever since, he has had trouble with the ABS. No lights stay on for him. It just activates the ABS system everytime he nears the end of a stop(turning or straight).
try this worked for my 97
Ignition on
jumper E1 and Tc in diagnostic plug
Abs light should flash then short break then flash again. This is the 2 digit code. May do this several times before long gap then start all over again. This means more than one code
Clear the codes by doing the above then pressing the brake pedal more than 8 times in 3 seconds Don't do this untill you are sure you have the codes.
If this works give me your email and I will send you a complete diagnostic procedure. There is more but to much to post
He needs to clean the sensors, front and rear. I did my front axle service and had the same thing. It was just coincidence that about that time that one of the rear sensors had finally gotten enough metal flakes on it to trip it.
I can not believe people drive with inoperative safety devices.
Especially Abs!!!! I was coming home one night on th open road at 100km/per hour (60 mph) when a truck pulled out in front of me and stop in the middle of the road. If it hadn't been for the Abs Me my wife and our 2 kids would be dead!!!! NO s*** It allowed me to swerve in a panic situation and stop well past the truck. If my Abs Was faulty the only place to drive it is to get it fixed.
