ABS Light/VSC TRAC/VSC OFF/ BRAKE
Waterford, NY
Every now and then I start my car or I am driving and my ABS Light/VSC TRAC/VSC OFF/ BRAKE lights come on my dash.
The brakes operate completely fine, no noticeable difference. I usually don't notice because until recently I had check engine and about every light on my dash.
Typically, like this morning. I just turned the car off at a red light and when I turned it back on it all lights were gone.
It seems like nothing changes when these lights come on but because it is brake related it is concerning.
Anyone ever have this?
Can I get into the ABS module through tech stream?
ABS lights on, no CEL. If mostly happening, just after first start of day. More so on cold mornings. Points to, brake fluid pressure issue.
First, rule-out low fluid level. Make sure to: Read what is embossed on the brake fluid reservoir, on how to set/check level.
Fluid okay:
Next, on cold morning before first start or more than one press of brake pedal of the day. Insert IG key, turn to ON (don't start), with hood open. Watch front of reservoir and listen to brake master booster pump motor. All seem normal. Once brake booster motor stops running. Pump brake pedal rapidly. Count how many pumps until ABS alarm and dash lights. The more pumps the better, indicating building and holding pressure well. Only a few pumps until alarms, is a sign of pressure issue.
When seals inside brake master and calipers are cold, as when any cold seal points. They don't seal well cold. With use, they heat up and expand, making a better seal. We'll typically see these cold seal brake alarms. Worsen with time and use, especially during cold weather.
Some of these are leaks between master and ABS unit (black box on master). Often, if we look close within minutes of alarms. We see wetness on bottom of master. Some even signs of leaks below brake master on inner fender
Some are seal(s) inside master. Which is internal leak. So no leaks can be found.
Some are weak or bad booster motor and or accumulator.
Some, low voltage.
There are other issues, not fluid pressure related. Like wheel speed sensors, zero point calibration or the very rare CPU or other sensor issue(s). But they have little to do with cold.
