ABS light safety question
Boston
Hello all, i know other threads exist and I’ve read a bunch of them in the past hour but i am about 500 miles from home on a long road trip with a dilemma.
Out of nowhere I started getting the ABS light and beeping sound upon start up. Every time I turn the car off and turn it back on the light and beeping occurs for 10-20 seconds then disappears. Do you think it is safe to drive it 500 miles back with this issue? Brakes feel good, no leaks, fluid level good. I am just very concerned about break failure considering I’m traveling with my pregnant wife.
Some opinions would be greatly appreciated.
2002 with 258k miles btw
Have you timed how long the booster pump runs before it shuts off?
How does the motor sound? Smooth, rough, Squeely?
I believe normal running time when starting cold is about 45 sec then stop, then run again for several seconds then stop.
After that it should only run intermittently while driving and you wont hear or notice it running.
If it sounds normal you may be ok, just drive safely, be ready to downshift and grab the emergency brake.
Hopefully you emergency brake is in good working order........
Thanks for the reply, so I did time it. Depending on how long the car has sat it runs anywhere 10-25 seconds, it sounds fine, just the usual hum. Yes tried the emergency brake in the parking lot after going about 20 mph and it stops pretty quickly with that lol plugged in my reader and no codes are popping up, I can get it to flash the light and beeping occurs almost every time I turn the car back on after a 30 min or more after it’s been off
ABS codes wont show up on most readers. You'll need the high doller one for those to show up.
If the light is coming on and you're getting the beeping, there should be codes present. Maybe an auto repair shop could read them for you.
Good luck on your trip.
Very likely your brake master is failing.
1) Check fluid level. Read what is embossed on brake fluid reservoir, on how to.
2) Check for leaks.
As a rule. I tell people, if ABS alarm comes on pull over. Alarm is due to brake fluid pressure below minimum. If this is due to brake booster motor failing to run on demand. You will lose brakes. But you description, does sound like this. But know this; Brake booster motors can either just stop working for good. Which you'll have no brakes. Or they can be intermittent, which brake may seem okay. But at some point, these intermittent booster motor, will not run and brakes fail.
As long as booster motor runs and we have brake fluid, we have brakes.
Provide brake booster motor is running, when ABS alarm is heard and alarms shuts OFF rather quickly. We can usually drive. Again, provide ABS alarms shuts off.
When ABS alarm comes on, on cold start. Meaning, vehicle has sat without pumping brake pedal, Like when parked over night. Then as IG key turned to ON, brake booster motor runs Until brake fluid pressure reaches, a specific pressure range. If range, not reach or takes to long. We get ABS alarm.
When seal within brake master system weak. They tend to fail to hold full pressure, when cold. As brakes used, fluid heats. Heat expands seal, and thus they seal better. ABS alarms go away. The colder the out side air (OAT). The more this well happen. In time, alarm well become more common. Even on warm days or even after brake fluid warmed up on cold days.
One of the seal that fails, the most. Is mostly due to poor fluid care/health over the years. Black fluid and or stained reservoir are clues of poor fluid care. A seal in front of master, seems to fail most in these. We'll hear a squeal (dying Seagull) and see bubbles come up front of reservoir at same time. The condition just gets worst with time/use.
Also if brake master has a leak. We also get this alarms. They tend to be less reactive to being cold, but they too happen more when cold, at first.
Look a brake master, for leaks. Feel around bottom for any wetness. Especial between ABS unit (black plastic box on side of master, 3 wire housing blocks attach to) and master (silver reservoir and ABS unit attached to).
I have seen, where the ABS unit itself has internal issue. Where only issues is the ABS alarm. We have no other clues. Replacing brake master is the cure.
BTW: The time test of brake booster motor run time. Is after pump brake pedal 40 times, with IG key OFF (Full Evacuated of Accumulator into brake reservoir). We testing how long system takes to build pressure, form this full accumulator evacuated. With 12.5 Volts at battery. We're looking for 30 to 40 sec max. This test is a check for air in system. It also give clues to health of: fluid, booster motor, booster pump, accumulator and seals.
2) Check for leaks.
As a rule. I tell people, if ABS alarm comes on pull over. Alarm is due to brake fluid pressure below minimum. If this is due to brake booster motor failing to run on demand. You will lose brakes. But you description, does sound like this. But know this Brake booster motors can either just stop working for good. Which yo have no brakes. Or they can be intermittent, which brake may seem okay. But at some point, these intermittent booster motor, will not run and brakes fail.
Thank you for the write up I really appreciate your time. FYI not sure if it changes anything but I get ABS codes C1251 - pump motor circuit malfunction
C1223 - ABS control system malfunction
Also I do see some leaking on the abs module
As 2001LC said, after you pump pedal 40 times with ignition off and then turn it on, how long does pump run?
Just did it twice, 36 seconds both times
When did you get the C1251?
If leak at ABS as you say (pictures). Plus DTC C1251 Plus ABS alarm. You'll need a new brake master.
BTW: Always clear DTC, and see what returns.
If this is a case of leak at ABS.
I'd drive and monitor closely: How frequent ABS alarm and when. Be very vigilant on checking fluid level and listening for brake booster motor to run periodically as it should. But, replace that brake master ASAP.
See wetness towards bottom. I get both codes almost every time I let the vehicle sit and start back up. Buzzer and light stay on for anywhere from 5 seconds to a minute
Replace the whole deal Brake booster ASSY w/bake master.
Yeah, replace entire master cylinder. Toyota OEM only.
Perfect just ordered one from local Toyota, $1,200 seems like a good deal, at least I hope it is lol
I’m assuming best choice is the unit straight from Toyota?
New Totota/Lexus OEM. Best and only choice. We ~5 variation for 98-07 100 series USA. So, Make Very Sure to use your VIN # when ordering.
Thank you 2001LC, TahoeZ, and badlander for your help with trying to diag my ABS issue, was hoping I wouldnt have to replace the whole ABS unit but seems like the best option considering its original and has 258k miles of use, ordered the correct unit should be delivered tomorrow. Was a nerve racking 550 miles back home considering the warnings would come off and on every hour but made it in one piece. A Christmas miracle lol
