ABS Delete and Clean up
48.493445, -116.881603
Website
www.orttauq.com
Now that I have deleted the ABS can I remove all related wires on the axles? Or are they used for other things in ODBII? 4WD?
Doing a full rebuild on the front and though maybe I could plug the sensor hole at each hub - weld shut or tap and plug.
whaddyathink?
whaddyathink?
Having no ABS for a while now I would like to see an O-ringed aluminum plug to replace the sensor. Simple bolt in is my thoughts without any modification to the housing needed.
Have you found anything like this? Removed tone rings but still have the sensor plugging the hole...
That's what she said.
Nothing I could find. I figure one would need to go custom. One of those things that is a straight forward easy part to make if you have a lathe:rolleyes:
With the right type of plastic it may be a good application for 3d printing? Almost no forces.. just temperature and grease resistance..
We could probably chop the bottom off of a stock sensor too.
