ABS dash light stays on
97 LX450 with 180,000 My ABS dash light comes on when I start it, goes out for two seconds and then stays on while running. Any suggestions on checks to isolate the problem, Former mechanic so be as technical as you want. Bought it 6 months ago and not familiar with the truck. Thanks a bunch. Ed
There are 2 sensors on the front knuckle and two more inside the rear drum. One or more is bad. They are expensive to replace new and a pain the butt to troubleshoot.
Has any work been done to these areas lately?
Thanks for the help. No work has been done and no bush blazing taking place-all good road travel before light came on. Any special tricks to removing the sensors, on just pull them out and clean them? Any help appreciated. Thanks -Ed
Ed, i hate to say it, but mine has just started doing the exact same thing. The only thing i have done is removed the front sway bar, then whallah....ABS light!!
One thing to try, is to remove the ABS fuse and disconnect the battery in an attempt to reset the computer. I tried and didn't work.
Next thing is to pull the ABS sensors out of the knuckle and clean them up and inspect them. That's the next step.
