I got my 80 on the road after the full Slee 4 inch. I screwed up when installing/bleeding the brake lines and let the resevoir empty. It took a while to get everything pumped back up. Got the brake lines bled out and everything felt great. Take it out on the road and the brakes feel really good (35" tires), the only problem is the ABS cycles at really low speeds when comming to a stop. It cycles in parking lot speeds and if you are approaching a stop. Nothing at high speed or anything like that, it stops/slows fine at higher speeds. I am not sure if maybe there is air in the ABS pump or something else. Anybody got any fixes or ideas? I'm not sure how to get the air out of the ABS pump if that is the culprit.
Jack
Jack
