? about 2F Engine Mounts
SW Kansas
I recently bought a 2F engine that was in a FJ-60, and am swapping it in where an F engine was. the motor mount brackets are a little different because of the bracketry for the air pump, and other accessories, but I need to know whether I need to use my old F engine motor brackets on the engine, or am I able to use the brackets that came on the engine from the FJ-60.
Thanks,
you could probably
Thanks,
use either one.
if you keeping the smog stuff use the 2f mounts.
otherwise strip it..
I can measure on sat. but the frame of the 60 is slightly wider than a 40.
I got the engine in, using the fj-60 mounts, I had to remove the A/C compressor, because it was in the way of the battery box. wish I coulda used the compressor for on-board air though.
Check out www.kccruisers.com for a simple York bracket for your 2F.
Been using one for several years now-no problems and all that air is great to have!
IMO better off with a York than a Sanden-style compressor anyway...
