Aarrrggg. Electrical help please
Longmont, CO
Okay guys here is my issue.
I had an electrical gremlin a little while back that I thought I had fixed but it seems to have resurfaced.
The gist of it is that my cruiser wont start unless it is jumped. I had the batter and the alternator tested and they are both operating correctly.
I thought that it something was draining my battery while it was running so the past 2 nights I have hooked up by battery charger but I get nothing when I try to start it. There is barley enough juice to get my EGR light on when on the ACC position.
After I jump the pig. It will run but it is defanetly in need of more electricity. For instance if I have my headlights on and my heater, when I turn on the blinker the head lights will flicker as the the turn signal turns on and off. Or if I use the rear window switch the heater will stop running. But the second I release the switch the heater will come back to life.
When I had first come across this issue I took out my battery and alternator and had them tested at Napa. They said that they were operating fine. And when I installed them again the pig started up with power to spare. But on Monday the problem re-surfaced.
Does anyone have any input as to what the issue could be?
Thanks guys.
Here are my questions
1. Is the alternator charging the battery
2. Will the pig not start with a charged battery.
One thing to check right way is the connection from the battery to the body and/or frame. If there is any questions, clean the contact point on the engine or frame. Also check the connection from the alternator to the battery - is there a voltage regulator on this pig? If yes, check it to as it could easily be the problem.
Assuming that's OK, then you'll need a volt meter (I assume you have an amp meter in the pig). Charge the batter all the way up and confirm with volt meter. Drive pig around. Check battery with voltmeter. If the alternator is charging the batter is should be at least 12v. If not, it will drop below 12v. The behavior yoiu were talking about with the fan and the other accessories could all be due to a low battery.
How old is the battery?
If the battery is fully charged and the pig won't start, then we need to look at some other things, but we need to know if the battery is charging first.
Peter
Clean terminals, check cables to make sure they are tight. Make sure gounding point for negative cable is clean and tight.
Simple way to see if your charging system is working is to disconnect the negative terminal form the battery when the truck is running. If it dies, you have chargine issues.
Good to go. I am at work right now. But when I get home tonight I will get her running and pull the negative cable to see if she is having charging issues ( as I don't have a volt meter). And I will disconnect the ground to the frame and clean if off.
I have heard tales of there being multiple grounds on Cruisers. Does anyone know if there are more than the one to the frame on a '76 FJ55?
One more thing when it comes to battery cables. I had an old set of cables on my FJ40. When I was having problems, I cleaned the connections and still ran into problems. Eventually, after much reading on ih8mud, I just broke down and bought new cables. My problem was resolved.
After further inspection of the cables, I found that the braided cables had oxidized at the point where they joined the battery post connector.
Well okay here we go.
I jump started it as usual and pulled the negative cable off the batter terminal. Nothing happened it kept running so apparently it isn't having chage issues.
I unbolted and cleaned what grounds I could find. There was not a strap from the starter to the frame.
As far as I can tell (with out a volt meter) the battery is fully charged. As it has been charging all night on with my neighbors battery charger set to 12volts at 2 amps. It has a 12v12amp option but he said to go with the 2amps. I dont know as I haven't had to charge a battery before. And the pig still wont start under her own power.
Any suggestions?
So wait, you had to jump it from another car - it ran - you could disconnect the battery and it cotinued to run - and yet it won't start on the original battery?
Replace the battery (or at least try a different on), it might be holding a charge, but no longer be capable of storing enough juice. What does it do when it won't start - does it crank poorly? Does it not crank at all?
Peter
If it's the stock charging system could the voltage regulator cause these kind of problems? A volt meter would definately help in the diagnosis, They've gotten pretty cheap and could save you some time.
When it wont start it may click once, but thats it. But it's not a mechanical click of say the starter trying to turn over it is an electrial click.
It doesnt even have the juice to run hazards or fans or anything when on ACC.
When the wife gets back from work I will pull the battery from her van and throw it in there to see if it works. I dont know if it is the battery because when I first had this problem the monkies at Napa tested it and said it was fine. But that was after it had been charging for a little while so. I dont know any more.
Sounds like the battery to me,the battery can be charging and still have 12-14 volts on a volt meter and looks to be in good shape but because of a dead cell still not have enough juice to start a vehicle(happened to me more than once)
I had the exact same promlem with my buddies Heep. Turned out to be a body ground issue. Make sure you've checked all your grounds, you may want to borrow a continuity tester if you know someone who has one, this can make your life a lot easier.
Good luck, Kevin
You're really shooting in the dark without a voltmeter. Harbor freight has em for about 8 bucks, if you have one there. Batteries can hold a "surface" charge, but not have enough deep power to crank. Easy enough to replace both the battery cables, won't cost over 10 bucks.
I've had that problem with a corroded positive cable at the STARTER end. Did you take that off and clean it up?
Owning a good voltmeter is MORE important than owning a tire pressure gage, jumper cables, a flashlight, emergency booze, cigarettes, a dictionary, a spare tire, condoms, and I am sure much more.
You cannot diagnose s*** without a voltmeter and an understanding of how it works and what it is telling you.
So break out the dictionary, get a good DVM and go to town. We'll be here to help when you get back.
JB
You might try bypassing the fusible link. It is the path for all power to the accessories such as headlights, heater, wipers, starting circuit, etc. I would like to know where you are connecting the jumper cables when you get it to start. To the cable clamps on the existing battery or down on the starter stud where the positive lead connects? On my 40 the fusible link does not attach in the original way. It is ring terminaled to the positive battery clamp with the compression bolt. If yours is similar, connecting a jumper cable there could be improving the connection allowing full power to the starting circuit. Just some things to ponder.
Leon...
When I jump it I attach the cables to the battery terminals. So I am thinking more and more that the napa kid had smoked something prior to testing my battery. I may just go out and purchase one this afternoon.
I didn't have time to rip the battery out of the wife's van last night as I needed to go to bed before she got home. Sucks waking up at 0400 so you can be at work at 0445.
