Hate that this has to be my first post on on here but here we go...
I have a 2007 Lexus GX470 with about 245k on the ODO. Not too long ago, the transmission cooler in my radiator busted and leaked into the transmission, requiring a replacement due to a couple codes I received on my dash (P0776 and P2714). Which sent me on a huge rabbit hole where I dug through countless transmission threads on here, finding that the answer is replacing the transmission was what I came up with. So, $1800 dollars later, the same issue still occurs. With the same two codes. I will post the Techstream picture of the codes from my reading today. But I have topped of the ATF at least 4 times, reset different things inside the car, still the same codes. Planning on checking the PCM connectors tomorrow, but wanted to make a post asking for help/ideas before I dump $600 into 2 shift solenoids. Thanks a ton, any help is appreciated and I will try to be as active as possible to respond to questions if any arrive.
