a442f transmition problem
Hi, these cables over time stick in their sleaves. You may need to drop the pan and take the cable off and soak in cleaning fluid or replace the cable. I have had to replace many cables. Mike
Did you tighten it or loosen it?
They *really* stretch over time; don't be afraid to tighten it significantly beyond OEM specification.
You'll know if you have it too tight by the really hard/slamming shifts between gears.
CJF, I certainly didn't mean to offend you. I am merely trying to help a fellow mud member diagnose his problem. I'm sorry I missed the threads on TV cable tightening here on the 80 section as I do spend more time on the 60 and 40 sections.
The fact that the fluid is dark and smells is a clear indicator that the tranny has not been maintained and more importantly, it has been overheated. When they get overheated the o-rings on the clutch pistons get very hard and over time can begin to be slow to actuate. If severely overheated, the seals begin to break down and smear on the housing walls also slowing clutch actuation. Both of these conditions can cause flare between shifts as well as clutch plates that are worn out.
I would drop the pan and do a filter change and see how much sludge and clutch material is in the pan. I would then refill with some high quality tranny fluid and then do a passive flush of the tranny and also try tightening up the TV cable as CJF said. Although, if you did indeed already tighten it and it got worse and you probably have larger issues with this tranny. As CJF said, it is ok to go tighter than factory specs on the TV cable due to the fact that they do stretch, but if you start downshifting at 1/2 throttle then you know you've gone too far.
Don
Don
No offence; just making sure he tries the simplest path first. But yes, if that doen't work, I agree your further suggestions are spot on.
One minor point: On an A440F, cable too tight will indeed result in downshifting too soon as you mentioned, but on an (electronic) A442F it should only result in shifts that are overly firm/harsh, while the electronics still dictate the actual shift points.
CJF is right, the TV cable on the electronic A442 is only for increasing line pressure, not for downshifting. Good catch! And yes, the simplest solution is always the best to try first.
Don
Hi Diego, any update on you transmission? I got the exact same symptoms with a fz80 I own. Would like to know if and how you remedied it.
