Your guess is as good as mine, I have an A442F on my TLC and it is a 1995 without ABS
just went out to take this pic...sorry, need to clean the TLC more...
Also, if anybody could tell me what the other numbers mean...I know (so far) that the K295 means it came with no diff locks (obvious) but the 1A6 FN10 have no clue or the A11...my guess is that at least one of those is for the car colour...
So, when you adjusted the kickdown cable, you got it to improve a bit? Which way did you adjust it? I ended up tightening mine quite a bit to get it to shift down correctly.
As for lurching/clunking... I'm not sure. You did check to make sure that your transmission fluid is topped off, right? (Guys correct me if I'm wrong on this) Typically, you check the transmission fluid when it's warm and the engine is running. If you check when the engine is turned off, you might think you have enough but actually you might be running low. (that's how it is with old Jeeps anyway...)
Transmission fluid is checked hot, engine running, slowly row through the gears and then back to P or N, and check the level against the HOT line on the dipstick.
@Catchsash if you have an auto trans, you don't have a clutch. Were you able to get a buddy and listen to see where exactly the noise is coming from?
...but the noise I am mentioning is pretty much while shifting from 3 to D
Yes for testing purposes only! otherwise it does on it own but slips hard sometimes.I don't understand this... when do you shift from 3 to d? Are you manually shifting this auto transmission?
Oh, I get it now. Did you have a chance to check your transmission fluid level, with a hot trans and your rig running? Your symptoms sound similar to low fluid to me. If it's not that, I wonder if you have an issue with your torque converter or have some sort of blockage in a line...
