A442F clicking noise
Orange, CA
Does anyone have any idea why my transmission makes this clicking noise? It happens when shifting between Park, Neutral, Drive or any gear really. Also happens when you hit the gas or when the gear shifts on deceleration. Truck just got back from repair with new torque converter.
Truck drives fine otherwise with no other issues, leaks, or sounds.
I would ask the repair shop that did the work to make sure it's not a problem. Please post their answer.
Repair shop says they can't figure it out. Gave the truck back to me knowing this noise was there. To be fair, I said if it's not a catastrophic issue then I really need my truck for the weekend to move a few things for the house. It'll have to go back to the shop sooner or later, but would be good to get an idea of where to point these guys to look.
Checked torque converter bolts, bellhousing bolts for tightness? Hell, check all the bolts...
Whole transmission was dropped just a couple weeks ago. Nothing could be found and everything tight. Possible drive shaft issue maybe?
Was the noise there before the repairs?
Yeah among other noises. Everything else seems to have been fixed except this. I don't notice any driveability issues, no smoke out of the exhaust, no leaks, no shudder changing gears. It honestly sounds like something is loose but I can't find anything. Someone once mentioned bad solenoids but im not sure that would make this sound?
......It happens when shifting between Park, Neutral, Drive or any gear really. Also happens when you hit the gas or when the gear shifts on deceleration.......
This tells me it has something to do with the transmission.
Your answer to this question:
This makes it not the repair shop's work that caused it - it's an additional, but necessary bit of info. Yes it does sound electrical - like a solenoid or relay clicking.
This would give me serious doubts about the quality & knowledge of this shops work. It is a transmission shop, right?
Loose exhaust brackets or heatshields, mounts? From your description it sounds like it makes the noise when the driveline is torqued over, accell/decell and when running through the gears...
I guess it's possible. Someone underneath truck while you're moving shifter should be able to determine source of noise. Stethoscope on tranny or other suspect source if any doubt.
Edit: A good shop would already have done this.
If you listen closely, most of the time it's a double click. Near the end, there are 2 separate single clicks. A healthy solenoid or relay is usually a single click. But' it's the volume of the clicks, too, that make this a mystery.:hmm:
Here is another video underneath the truck. Hard to tell. Is that wobble in the transmission when I hit the gas normal?
Loose transmission mount, stressed/damaged motor mounts from dropping the trans? Unjointed/slipjoints stressed or damaged during the repair?
He had the noise before he took it in to the shop. Watching the 2nd video, the sound seems to be in sync with torque movement of the engine/tranny. Being it's the diesel, I'm not familiar with motor mounts. Maybe a post over in the diesel section with the 2nd video might get some replies.
Here is another video underneath the truck. Hard to tell. Is that wobble in the transmission when I hit the gas normal?......
IMHO, there doesn't appear to be a broken or weak motor mount. But, a diesel mechanic might have a different opinion.
All of my suggestions have been agrivated by dropping the trans.
I know with my diesel the engine rocks a fair bit when the pedal is pushed, and actually every vehicle I've ever owned has done the same to some extent. Since the transmission is connected to the motor pretty firmly, I would assume the transmission should move too.
I'm not an expert, but that movement didn't look out of place to me.
I get what you're saying, but since the shop dropped the tranny, you'd think they'd notice a weak or damaged mount and bring it to the owner's attention. By the OP's posts, he's talked about it with them. "Repair shop says they can't figure it out." Looks like the OP lives in Orange - the shop is probably close by and should have experienced mechanics. Wierd!
