A440F rebuild question
jynx
Turd Herder
Eagleville, TN
I realize that this is a bit of a long-shot and not your typical tech question, but I was curious if any of you had taken on rebuilding an A440F or other hydraulic Toyota transmission? Where you bought new steels, friction rings, gaskets and such?
I have a couple of projects on the brain and while one of my 3FE powered rigs is likely going to be getting a 4spd swap and some other goodies soon, I am thinking the other needs a freshening and as with many of the things I read about, it seems that the rebuilding of a hydraulic Toyota trans seems to be something that requires a bit of knowledge and I am hesitant to drop $2k or $3k for someone to rebuild a trans only to Eff it up. I can Eff up my own transmission and while I may watch too much TV, those auto shows that I watch on the weekends make it seem like they aren't a great deal more than pulling a bunch of parts out of the case, putting in new steels and then putting it all back together. The valve bodies seem to be where you can get into trouble, but I am sure I could bolt one of Rodney's Nomad valve bodies up to take care of that, then drop in one of his torque converters and be good to go.
Am I missing something. I am not afraid to take on the challenge, that is unless there is some crazy tool that is needed to take things apart or put them back together.
Appreciate any feedback
Thanks,
Matthew
You might look up mud member:
longbow
pretty sure he has experience with a440f.
