So, Sheila is having issues with the transmission in 2 & L gears; specifically, when in 2, low power/no kick down when gas is floored. In looking at the cable linkage, and trying to adjust per the FSM, the cable appears very loose between the orange boot and the cam with the throttle cable. Is this correct, or is the cable just old & stretched out- replace it? If I adjust the cable to be somewhat tight, the adjustment specs from the FSM go right out the window, which leads me to believe that the cable should be replaced. I am also getting ready to flush the transmission... Any insight would be much appreciated!
EDIT: Please ignore my temporary 'fix' with the hose that reads 'not for under hood installation'
