A440 behind a 4bt?
5,280 ft
Website
www.dadirriextracts.com
Am in the process of collecting info on a 4bt swap, And yes im on the waiting list.... Would it be crazy to keep the A440 w225k on it, with an adapter, in lieu of opting for a new 700R4? If it ain't broke don't fix it right?
I know they have proven they can handle the hp of a V8 tbi swap, but could the A440 hold up to 400ft/lbs of torque a 4bt could dish out?
Give me your opinions...Flame suit on:cool:
I mean my real question is: am I crazy to put at least 12k into it this project with a 16yr old tranny with 225k on it behind it.
I obviously like Toyota trannies and believe mine has a chance to outlast a new one.
I also cannot afford to loose my CDL (t-case) cause it saves my a$$ in snow and ice without having ABS.
You may want to e-mail or call Rodney in Australia. Can't recall the name of his company, but it is the one that does the cruiser trannys as well as others. He could probably comment. I'm guessing at a minimum the torque converter will have to change to match the rpm/torque curve of the 4BT.
Don
I'd want to keep the t-case, so that would drive me to keep the transmission, personally. I want every possible locked/unlocked option in a heavy duty case for Colorado winter driving.
Of course, if by saving your ass you mean CDL is on...that's just a part time case in 4HI and you could do an Atlas, get the serious extra low range, and engage it to the same effect as CDL on in winter driving. CDL on is not the extra feature on your case...it's CDL off in AWD. What you lose to keep CDL off (AWD) is a good t-case low range.
If you really want to preserve AWD...I'd step out of the 4BT line and into the forced induction line and save myself a fortune in time and money :D
I have thought about this exact thing as well. I know from Rodney's web site http://www.automatictransmission.com.au/extreme.asp it does say somethings about the problems with putting this tranny behind a V8. If I was going to do it I would get the extreme tranny and put it behind the power plant your chose. I am of the opinion you do it right or you do it again.
Matthew
Right on the money. I love the AWD safety.
Forced induction what?
not a 3ForEver
Yes, I essentially want to keep everything stock except the motor. Which I would keep if I didn't get 9-11.5mpg.
The money I would save would be about 2k+ per year on fuel as it is priced now.
maybe its not possible. I really dont want to do the 700R4, fj60 case, part time kit.
Dont waste your time with the stock tranny, they are very stout for their intended purpose, but that 400+ Ft LBS will drop that old tranny like 3rd period french, a lot of ppl have spent a lot of time and $$ to figure that out in the end, V8 OR DIESEL. Also drop the crappy stock case, 1. they get slop in them 2.they are full time 3. even if you do the part time kit, you dont gain much because your turning the viscous couplers anyway 4. they are not as small OR as stout as a fj60 split case that are pretty easy to come by and install, if your doing the swap anyway. PS you dont need the soccer mom AWD anyway, its 2 OR 4WD ONLY!
Just wondering if you have any chance to make a test and ensure the status of your tranny .. or could be a ni ce option if you wanna keep it, do a rebuild .. there is a reputable auto tranny shop to do that in USA .. ?
I dont think his is viscous. If he has the same as me its not. Full time wears out your front faster but look where he is driving.
Matthew
Thant being said. I have thought a lot about Ram Jet 350 - 700R4 - Atlas. That would be really nice. But money....
Matthew
Why not? What do you want to accomplish my making a swap?
Goal,...to DD a rig on 40's:D
I am happy with the current setup with the exception of mpg's.
Who did yours and what is behind your 4bt?
I knew it :D
That's a terrible goal :D
I'd be looking at Dana 60/70 with the extremely low gear options, like 7.07 or whatever is the low gearing. Then swap a Toyota V8 and leave everything else alone.
You'll spend less money, get the axles you really need for 40's, and keep reliability with a silky smooth V8. The stuff in the middle will be fine.
A 4BT on 40's means new axles anyway, might as well do the axles to get the super low gear ratios and keep a better DD engine.
Or leave it on 35's, put in 5.29's, and wheel it :grinpimp:
Dana 60 cant be that much stronger can it? Especially your FF rear. Isn't it comparable?
IMHO, With a 4bt I would have a killer idle over everything gearing anyway.
V8=sucky mpg!!
Opinions, opinions. Thats why I posted!
I like to break axles before I replace them. I don't have the same attitude when it comes to body damage=sliders and armor first!
I would say a 4bt would be a pretty decent DD seeing as they can last 500k if properly maintained while getting low to mid 20's for fuel mileage.
Dana 60 front / 70 rear (or 14 bolt). FF just keeps you rolling when those 32 spline smallish diameter axles bust.
Let me preface this that I am not recommending to Jason to either keep or drop the 80 series transfer case.
This is the first time I have ever seen someone call the 80 series transfer case crappy. We have never seen one fail, except for the viscous coupler. Jason does not have a viscous coupler, he has a 91/92 truck. I am also not sure where you get the info that it gets slop in it. I would take a 80 series transfer case any day.
I am not experienced on the 60 series split case, but I doubt it is stronger than the 80 case. If you install the part time kit, you can have the same 2wd/4wd.
The biggest issue with the A440 is the shift points. Whatever tranny you choose make sure the shift points are compatible with the 4BT. Otherwise it will be a pita to drive.
I assume when Nay speaks of Dana 60, he would mean that it is fitted with 35 spline internals.
Do you still get mid 20's on fuel mileage when you have turned up the 4BT to get those 40's rolling? :D
Isn't somone trying to put an Isuzu diesel in an 80, might be called a 3B? I agree though, it would be nice to be able to install a diesel motor and reuse the stock trans and t case. has to be a lot cheaper that way too. I have read the 4BT is very loud at idle and vibrates a lot. I dream of a diesel 80 too, for the fuel mileage, longevity, and the ability to run biodiesel or Waste veggie oil. Imagine running an 80 on a well executed WVO setup, you get your fuel for almost free!
