A very Different A.C. question
Website
www.maxx-racing.com
Okay so this isnt a normal 80s question but I hope one of you guys are up on your AC systems.
Okay so I am fitting a Tundra V8 (Using the existing compresser R134a) into an FJ80 (R12) so here my problem, I have all the AC parts from the 80 (behind the dash) which I will be using and wiring it up hasnt been to much of a problem. I am curious as to what I should/will be charging up my system with- R134a or R12?!
I know and have heard on numerous occasion that R12 does a bit better cooling and the 80 series is not known for being an icebox but any little bit of an edge I can get would be great.
I think the compressor would be fine to run R12 in and as far as the ozone layer goes MEH, I wont spill any;) (I have the equipment to recover and charge at my disposal)
anyone familiar with both systems and could steer me in the coolest direction it would be appreciated, any advice or pointers.
I believe the system should be fine to run either R12 or R134a but it was built to use R134a which is better for the environment, cheaper and easier to get than R12 (which requires a license to buy and handle).:doh:
I have not had the chance to work on R12 systems but I believe that the only differences between those and R134a systems were minor. There were simple conversion kits available to convert R12 systems over to R134a that anyone could buy.
Good luck regardless of what direction you wind up going in.:cheers:
From what I understand the oil is different in 134a vs. R12. This could cause problems with the compressor, but I am not certain about that.
FWIW I have a very slow leak (need to re-gas every 2 years) in my R12 system. Last summer I was not able to find any so I picked up some Freeze12 off ebay. It came as a kit and was easy to install. On the hottest day that SOB was blowing snow. I couldn't keep my left hand on the wheel by the vent as it was going numb. Whole kit cost me around $70.
There is a Toyota TSB on converting from R12 to R134. PM me your email and I'll send it to you (Can't remember link for you to web it.) This will explain all you need to do.
Additionally, you can get a new receiver/drier from Autopartswarehouse for about $40.
New o-rings are a must.
Are you going to use the 80 compressor or the Tundra compressor? You did not specifically say that's why I ask. If the tundra compressor, then think about the 80 expansion valve. Will the tundra's pressure be okay with the 80's expansion valve. (Just thinkin outside the Cruiser!)
I am also very interested in the necessary things to do a R12 to R134A conversion. I have a Nissan Pathfinder which still runs R12 and I am having leaks. Constantly filling it with R12 is a PITA (very expensive and hard to accomplish as most shops here use only the newer filler). I have to do such a conversion and would be grateful for any materials.
Yeah thanks for mentioning the fact I didnt put which comp. I am using, it will be the tundra compressor.
Since you're going to use the Tundra/134a compressor, it would make most sense to use 134a as refrigerant. The only issue then would be whether the expansion valve is okay, since it was designed for R12. Since the R12 to R134a conversion kits never require you to swap out the expansion valve, you should probably be okay keeping the original one in the cooling box (i.e., no need to replace it).
I would be sure to pull a real good vac on the system and replace the receiver/drier.
You'll be fine running 134-a in the system w/ the Tundra compressor. Just make sure you use the correct pag oil for the Tundra system. Don't use pariffin based oil(mineral oil) because it can't handle the hotter temps of the 134-a,causing a very slow and painful death for the compressor. If your worried about the cooling capabilities in the Fj body you can always add an electric fan in front of the condenser to keep the high side pressure lower. The lower the high side pressure is the lower the temps are for the compressor. Hope this helps.
