A strange problem with ignition......
Los Angeles
This just started a few days ago and I wonder if anyone knows what it might be. When I turn the key to start, all I hear is a click, and no start. So I turn the headlights off and nudge the gear shifter a little (still in park) and try again. I know this is as crazy as a UFO encounter, but the engine roars up and starts. This was sporadic, but becoming more frequent. I don't know what a miniscule nudge to the gear shifter has to do with starting up....but it does. I have not been stranded yet, but I wonder if it is a gentle warning for a serious problem. The only thing that happened when this started is that, in haste, I had left the driver door slightly ajar one night, causing the dome light to be on. But the truck came to life after this very 'procedure' the next morning, without a jump. Could it be the cheap generic battery it came with is ready to kick the bucket? How could a little movement in the shifter and the starter be connected? Any idea what it might be?
I am seriously considering going all LED after this incident. Hard to live with 1997 technology.
Thanks in advance.
Neutral Safety Start Switch. Too tired to look up the threads but go into search and try it.
One way or another, with the kind help of knowledgeable people like you, the truck will be a-ok and healthy again. I would hate it to look pretty sitting in the garage with that diver's side mirror fixed.
While the Neutral safety switch is probably the culprit I'd clean your battery terminals as well.
Could be a battery that's on it's way out.
