A Simple 80's problem
Central America
hi, i need help, i'm a do it my self kind of guy...
I know this is old, but where is the LSPBV i need to flush the brake line, because i realized i was using DOT 5 for 2 years, and i just found out that is not meant to be used on an 80, so i need to flush all of the dot 5, and replace with DOT 4 Synthetic - I think synthetic will be more compatible with silicone DOT 5, so i have to bleed the whole system 4 brakes, the LSPV and the MC.
If any one knows where is the LSPBV and also something more that i need to do, to fully flush The DOT 5 OR if you know if DOT 5 can be use on a LX450 gasoline from 1996
your thoughts are really aprecciated
It is connected by a rod from the center of the rear axle. Follow that rod and you'll see a box with brake lines connected to it. That's the LSPBV
