a longfield Q
ok just a question (i know i am going to get a lot of S*** for this) i have a 75 front end with drum brakes could i run longfields if i changed the hubs to a 30 spline? yes i know "why don't you just convert to discs" well i have 4x4 labs steering and would need the same knuckle bolt pattern to make it work so if you have a 76 77 or 78 front end you would like to sell me let me know
No, The fine spline longs will not fit through your spindles. The OD of the stub is too big. Talk to Peesalot, he had Bobby Long do a set of coarse birfs for him. Now he's running some sort of bastard dana60/FJ fron end and may have his old birfs..... If not, call Bobby and see if he will do another set.
BTW, you will be dollars ahead if you just upgrade to disks now.
PMK
Smurfblue has got those now. I say run what you got until you go 37's and up then go mini disc conv. & longs.
Or build a bastard 60/LC hybrid like I did.
Pat , that bastard has your diff. gaurd on it.
