A least the D works!!!
Arkansas
Started her up and this happens. Seems all the backlights are out which is concerning. Anyone else have this happen??
Stealth mode.
I don't really have anything useful to add except maybe check that the dimmer hasn't been turned down past the (subtle) click.
The D light is the culprit. Mine has never worked and the rest are good. :rofl:
My d light wasn't working when I got mine. I went on a bumpy dirt road and all working now. On the other hand The rest of your panel cluster out seems like an unusual problem.
Fuse?
Did you recently take the instrument cluster out and put it back in? Mine had a really finicky connection when I did that.
Fuses all good. I pulled the cluster and reinstalled with no changes. I guess I'll pull it and it off to a cluster repair shop.
Does your radio still turn on? i had a similar issue (kind of), my dash and stereo went out at the same time and it ended up being a fried ECU due to water getting behind the glove box :(.
Radio works. All warning lights, turn signals, gear indicator lights as well as the speedo and tach needles light up. It's just the backlight for the gauges for lack of a better term are out. Turning on headlights makes no difference as does the dimmer switch, which is only dimming the needles. Thanks for the replies, I'll send the cluster off and report back.
