A/C recharge questions
Tijeras, NM
Since the wife was complaining of her 40th not producing cold enough vent temps, I thought I'd investigate what's up with her system.
Her vent blows at 40* during high speed cruising but it goes up to 50* to 60* during in town cruising.
The manifold gauges came out and I did an initial reading while looking at the sight glass.
18 psi Low/255 psi High, I see bubbles in the glass.
FSM: range should be 21.76-36.26 psi Low side , 198.7-227.7 psi High, bubbles = insufficient R134a
So, I add about 6 oz of pure R134a (no die, etc) and notice that my Low side is NOT increasing but the High side PSI is increasing and is now at 300 Psi :eek: Since this is beyond the range per FSM, I stop recharging and take her for spin. Not much of an improvement, still blows at 40* at hwy but 50-60* at non hwy.
Came back home and drained the R134a and pulled a vacuum with a pump. It held at -30hg for ten min and I commence recharging the system again with pure R134a using 12oz cans.
FSM calls for 30 oz +/- 1.76 oz so I put in approx 30oz (prolly a little less) and it looks like my Low press is at 20 psi, high side is at 255 psi. Low side is too low and high side is too high :crybaby: Recharging was done per FSM, A/C high, windows open, 1500 rpm,etc
I'm about to take her for a ride to see how the vent temps are but it's not that hot outside yet so not a good time for a test.
My question is why can't I get the Low side PSI to the proper psi range 21.76-36.26 psi? Is this an expansion valve issue?
Using a sight glass is a very confusing way to dx an A/C system for amateurs like myself.
FSM: When A/C is turned off, refrigerant foams and then stays clear = Proper refrigerant This is true in my case but the low & high pressures are out of spec!
What should be my next course of action? :confused:
System has no leaks that I can tell. From what I understand, a failed expansion valve means 0 psi on Low side and that is not my case.
TIA.
R134 is very charge amount picky, I usually under charge and creep up the charge using vent temp to get the best amount. It's also very temp dependent, higher ambient = higher head (high side) pressure. It sounds like insufficient airflow? Try spraying water on the condenser, head pressure should drop.
Thanks for the info Tools. I did a tx of Simple Green the condenser so we'll see how the vent temps are on the next drive. Stay tuned....
How strong is the fan clutch? Spraying some water on the condenser or blowing a strong fan at it while running will give some idea of performance change with better airflow.
Fan clutch is original Eaton with 10,000 CST from Toyota (two tubes). After the wash, the vent temp went to 38* :eek: but I'll wait until we go into town for supplies where it should be pretty dang hot today.
Forgot to mention, there is an aux cooling fan from a 4Runner in front of the condenser, on the passenger side wired according to Sumotoy (your favorite guy ;))
Thanks.
Thanks.
Sounds good, the rubber seal on the hood, over the core support is in place and the radiator foam?
Great! I'm keeoing an eye on this thread Ali :cheers:. Sooner/later I have to recharge mine; especially the way I am using my A/C. What can I say, it's hot out there and it is blowing ice cold air. I have blue fan clutch though. I am thinking of getting the aux fan; it will happen one o' these days.
:cheers:
Yup, still have the foam seal and rubber seal are in place.
Wouldn't you know it, we got a cloud cover and it's been cooler than normal :mad: While the temps climb up slowly, I'm busting a nut trying to break the tie rod end loose from the tube so that I can do an alignment......
Slight hijack: If one does not have the aforementioned foam, what could be used as a suitable replacement?
End hijack!
I use waterproof closed cell foam weatherstrip from the home center.
I have used the foam they sell to wrap around hot water pipes. Seems to hold up well against the heat.
well, she's spitting out 40* but it's not very hot today, so we'll try tomorrow to give the system a decent workout.
With regards to the radiator and hood seal and their effect on air flow, I found out that it's very apparent. With the hood open, engine running, the air being pulled through the radiator by the engine fan is not very strong. This is proven by the stationery aux fan blade.
However, with the hood shut and the engine running, the negative pressure created in front of the radiator is strong enough to make the aux fan blade spin.
You have an extra condenser fan..... the low side is too low and the high side is to high. Water across the condenser drops the temps of the freon, but today wasn't a good test day. I'm thinking expansion valve if things don't get better. Back flush it. By that I mean opposite the flow of the oil and refrigerant when the a/c is on. Flush from the low side to the high side. From the fat tube to the small tube. The lines at the firewall are all that need to be disconnected.
Household products on the condenser can't hurt.
Ok, I think I understand but let me just make sure. Basically, disconnect the two lines at the firewall, then use air pressure and some A/C system flush detergent and flush out the evap opposite of the normal refrigerant flow. Easy enough, will do after I run one more test. Suppose to be blazing hot in town today.
Thanks very much.
alia176; any progress on your A/C problem or tips on doing the flush?
You got it right. You will want to hold your thumb over the high side while blowing the flush through the evaporator and expansion valve. Let it build up pressure, then release, repeat the process several times. Use a rag and be careful not to get flush in your eyes.
Newb question; does this flushing procedure clean out the condensor? Read something online where they said all the debris and sludge in a system ends up in the condensor??
Well, we made our run into town and it was blazing hot down there. The vent temps just weren't satisfactory to say the least. Our best was around 45* during a long hwy stint. Before that, it was 60* and after exiting the hwy it was 50* so something is amiss here.
Ok, will do this tomorrow. After doing this, should I add any oil to the system, assuming that most of the oil from the evap will have flushed out? The FSM says to add a specific amount of oil once an evap has been replaced so this feels like a similar thing.
Thanks.
In my case, I'm ONLY flushing out the Evap. However, one should flush every single component to make sure all debris is out of the system.
Add back whatever amount of oil the FSM says after either flushing or replacing components. If I were to guess it's somewhere around 2 ounces, correct?
