A/C issues
Formulaonehd
NWZ - The storm is here
Pilbara Region Western Australia
Had a read through old threads, one touched on a very similar issue to what im dealing with but without a resolution.
Basically its a hot climate where i live, car has new rad, coolant system flushed 3 times, new belts, original water pump fine (new gasket), aircon was regassed and mech said there were no leaks they could find.
Yesterday went for a big drive at hwy speed for a couple of hours, in the morning the A/C was fine with day temps about 84F/29C. When we arrived the day temps had warmed to about 97F/36C and humidity was up. Had a look at the engine temp guage and it was below half but the A/C kept clicking in the dash and the air was only marginally cool, the engine kept idling up and down with the clicking.
Turned the car off and let it cool (in the stinking hot weather) for an hour or two.
When we left it was still clicking and it did this until we got close to the ocean where the sea breeze was blowing and temps were back around 86F/30C. The aircon slowly stopped clicking every 2 seconds to an intermittent click (air slowly getting cooler) and then it stopped and the aircon went cold again.
Now im no expert in cooling systems but there's obviously a correlation to outside temps and the cooling system not being able to cope with the hot weather outside even at hwy speeds unless under 85F or so. is this a sign of a tired compressor, blocked aircon rad? (both orginal 1993 with 95000miles) or some other common issue? I should point out the engine has to work really hard if you turn on the rear cooling system.
Cheers
Have a shop with gauges hook up and see where your low and high pressure are. All the rest are just a guess.
I'm not sure about the clicking sound, but one thing to check (if you haven't already) is detailed here: Check Your Heater Valve
Ahhh yes i see see crusty pink around the joins/clamps near the firewall will check the heater valve later after work
Your engine may be overheating, despite what the unreliable, crappy gauge says. This will result in kicking the ac compressor off. There are many threads on this if you do a search.
The a/c will shut off at something like 108C coolant temp...
Either you’re engine is teetering around that temp, considering load/ambient temp., or too much refrigerant. Too much charge will cause rapid pressure increase(especially with increased ambient temps) when the compressor turns on, then the high pressure switch turns the compressor off, pressure drops, compressor turns on, rapid pressure build, high pressure cut off, etc...
And doesn't come back on till it cools, significantly, so would not short cycle, more like tens of minutes, not seconds.
+ what @Tools R Us said above - So sounds like my temps were probably around 180 which is why everytime it cooled to turn start the compressor again then temp would go back up to 180 and hence it 'clicked' and switched off and so on so on?
I just remembered something else, i noticed was the power steering was also more difficult from a stop when reversing out of the parking bay.
108C = 226F
180F ok
180C not ok
I was saying if your coolant temps are around the 108C(226F) you could get cycling...
Tools is saying the cycling caused by
coolant temp would be a much slower cycle...
I would suggest checking A/C pressures when good and hot, and investing in a better coolant temp gage, something that will give you actual temp... 108C(226F) is too hot to be running consistently, maybe peak after a long steep pull...
^^^^^^^^ This.
Short cycling (rapid cycling) of the compressor can be caused by a number of things.
(Pressure) Too much or too little refrigerant charge. (most likely problem)
Blocked expansion valve.
Compressor failing.
Defective pressure switch.
Intermittent short in wiring.
This is correct, which brings us back to an over-charged situation considering that it has been re-charged. Once you are in the hotter environment, the head pressure rises and kicks the compressor off on the head pressure switch. The pressure then lowers and kicks the compressor back on. Cycling on, off, on, off, etc. If it was not done, the refrigerant needs to be removed and weighed back in, preferably after any and all leaks are repaired, and after a good vacuum.
Thanks for the info . The heater core valve looks buggered so my last question is : will a leaking/corroded heater core valve cause these issues or is that just another part that needs replacing with the recharge still the likely culprit?
I would definitely replace it as they get brittle and will fail at the worst time, like when you are out in the middle of the desert, causing a complete dumping of your coolant and overheating the engine. It has nothing to do with your ac compressor cycling, but was mentioned because they can bleed hot water through to the heater core, overriding any cooling effect from the ac system.
PS- we don't talk about air conditioning very much during this time of year!
Do not even touch that till you have another on the way. That will Crumble!
Got mine on Ebay for about $60.
The plastic becomes brittle.
