a 1985 2l-t vacuum question
Orleans California
hello all, i and reviving a rwd 85 turbo diesel. does anyone know why there is a vacuum line running to the injection pump? there is a the boost sensor and below that is a vacuum line, seemingly to the other side of the diaphragm... any ideas?
thanks.
A photo of what you are trying to describe would be helpful.
It seems for CA emissions the engine has both a boost compensator on the injection pump, and a high altitude compensator. I have never seen this before, but I assume it is to adjust off-boost fuelling at altitude. I am not sure why it seems to be linked to the EGR via a BVSV (bimetallic vacuum switching valve).
So you have a line from the intake manifold to increase fuelling on boost, and a line from the HAC to the other side of the boost compensator to reduce fuelling off boost at altitude.
Interested to see a picture of this.
this tracks, there is an entry in my FSM stating that "The HAC valve maintains vacuum from the vacuum pump at a consistent value in spite of atmospheric pressure change. "
here is a picture of my current plumbing.
i have removed my EGR system as the EVRV ecu-cotrolled valve was chewed up by mice.
