Parting Out 99 Landcruiser White
Do you have pig tails for side marker lamps ?
Have searched the thread and not found anyone claiming this -- but might be using wrong terms -- but do you have the wood surround for the radio/HVAC controls?
How much for the rear diff?
Do you still have the mounts and bolts for the second row seats? Do you have the trim piece that sites at the bottom of the drivers side door sill? Also looking for the blank plate/panel that goes to the right of the AC controls and the blank plate/panel on the back(facing 2nd row seats) of the center console.
EDIT: I believe the park numbers are 7130160020 and 91642-H1022. I need the Hing Sub Assembly for the larger second row bench seat that's on the drivers side, plus the 8 bolts with washers. I'd like to buy 2 additional bolts with washers if possible.
ISO of these grommets. They are part of the front door wiring loom. They are between the front doors and A pillar. Would you be able to pull them for me?
Do you have the rear cross member trailer harness? Its attached behind the bumper on the cross member. goes from one side of the truck to the other about 6 feet long has 4-5 plugs. Thank you in advance!
do you have:
Left Front Door
Left Rear Door
Fuel Filler
Rear-most trim (from wheel well to under tail-light)
Front Bumper
Front Bumper Impact Bar and foam
Rear Bumper
Front Grill
Driver Side rear view mirror (or just glass)
Driver Side taill-light (on fender, not hatch)
Driver-side Headlight
Passenger-side Headlight
I'll PM you as well.
Do you happen to have the center caps for the wheels?
Hi, do you happen to still have the wheel center caps? Shipping would be to 98335.
I believe I still have 2 or 3, how many do you need?
