Hi guys. I recently purchased a unicorn. 97, triple locked, single owner, supercharged...... and the check engine light is on.
My code reader says PO135 which apparently is caused by bad O2 sensor(s). I replaced both and the light comes right back so I took it to a smog shop.
The guy at the smog shop tells me that the sensors are shorting. He checked the wiring between the sensors and reports that it is all perfect so he concluded that “they are not being grounded properly at the ecu” and suggests that I replace it.
Does this make sense? If so what would be my best option for sourcing a new ecu?
Thanks for your time and suggestions!
