So been driving my 97 lx450 pretty much daily and today when coming home it died in the driveway and wouldn’t start again. It seems to be an EFI issue or fuel pump. Here is what I have done so far but have had no luck. I have read some of the threads on this but have not dug super deep yet. When cranking it literally sounds like it is going to crank over but doesn’t.
CEL is on when turning the key to the on position.
Checked EFI fuses by knees and in the engine compartment and they are good.
Fuel pump relay was checked and had 76 ohms so it is good.
Jumped fuel pump from relay and #3 wire and could hear noise I assume fuel through fuel lines.
Checked all 3 fusible links by the process below and they all checked out. I assume the charge lamp lights is the red/orange light above battery gauge.
FL1/AM1 (small ring terminal): if the dome lights work it's good.
FL2/AM2 (grey connector): if the CHARGE lamp lights when you turn the key to ON, then it's good.
FL3/FL MAIN (large ring terminal): if the brake lamps work when you step on the brake pedal, then it's good.
What else am I missing here? Maybe fuel filter? I appreciate any help you guys may give.
