97 antenna mast question
Nunya
Hi, first post here. Just picked up a 97 LC. 172557 on the ODO. I’ve searched but can’t find the answer to this question. My antenna mast works just fine but I would like to make it so it just operates with the up/down buttons and not retract/extend every time I turn the truck on or off. Seems this would extend the life of the mast. I have a FSM on the way but it won’t be here till Monday. Thanks!
No doubt that this is possible. Just get yourself an electrical wiring diagram, figure out how the antenna circuit works and then modify it to your liking. If you are good at reading schematic diagrams, it will only be a few hours of work to produce something that everyone else will think is broken.
i replaced mine, then replaced it again, then swapped it for a short rubber, generic antenna.
My first one lasted 15 yrs.
If not damaged (the reason most folks replace them) they should last quite a while. I suppose 'environment' has something to do with that as well. My antenna never gets coated in ice, mud, etc... The nylon 'tape' can become brittle over the years, but most folks have trouble with the 'mast' getting damaged.
