blunderbuss
80 series
I recently replaced my front springs and shocks and keep hearing a strange BOING noise coming from the front end. It sounds like a metal spring being plucked. I've read thru some threads, some suggest an ABS sensor wire or something hitting the brake dust shield. I've checked and that doesn't seem to be the issue.
While under the truck today I noticed the Radiator pipe No7 16577-66010 looks bent on the underside. Could the dent on the pipe be from the lateral rod? or does the pipe come bent from the factory to avoid hitting the lateral rod?
