I would first like to start off by saying yes I did use the search and didn't have much luck.
I've owned my cruiser for over 1 year. However it seems like more recently probably in the past two months the shift has been getting harder. This only occurs when above 3000 RPMs. Now I understand this is a twenty-year-old SUV with almost 200,000 miles on it but I do find it strange how hard it has been shifting. The fluid level is fine and the fluid is clean. I recently added some Lucas stop slip that is supposed to also help shifting. I believe it worked for probably one week and then it went back to how it shifted before. Now I do believe I will be doing a fluid exchange sometime in the near future as I do not have record when it was last done but is there anything else I can check before doing this? I looked at the kickdown cable and it was all within spec. I just don't want to be driving it if I'm doing more damage to it. Does anyone else have this issue?
Thank you.
Thank you.
